800cca Battery
Old Sep 13, 2014 | 11:30 AM
AARRA's Avatar
AARRA
Default 800cca Battery
Is there a battery for a '79 with a minimum of 800cca? Optima is 720 and I checked Advance Auto and Sears and neither lists any online. 850 is recommended for the stroker I ordered. They say "not set in stone but should be at least 800". I have no doubt it would start with 720 but I prefer to follow their recommendations if possible. Any thoughts will be appreciated.
Old Sep 13, 2014 | 11:47 AM
Street Rat's Avatar
Street Rat
Check this link for some high CCA batteries...
http://www.sonicelectronix.com/cat_i...%5Bmax%5D=1200
Old Sep 13, 2014 | 12:41 PM
C3 Stroker's Avatar
C3 Stroker
This one.....
http://www.summitracing.com/parts/ul...model/corvette
Old Sep 13, 2014 | 01:40 PM
another-user's Avatar
another-user
ive had a farm battery in mine before, was rated at something like 1100cca.
Old Sep 13, 2014 | 03:20 PM
Peterbuilt's Avatar
Peterbuilt
Default This one will work just fine.
http://www.napaonline.com/Catalog/Ca...578_0398817957
Old Sep 13, 2014 | 06:30 PM
7t9l82's Avatar
7t9l82
i have an interstate AGM battery that would jump start a locomotive.
Old Sep 13, 2014 | 07:04 PM
AARRA's Avatar
AARRA
Thank you. I called and they need the dimensions of the current battery. I will measure and call them again.
Old Sep 13, 2014 | 07:06 PM
AARRA's Avatar
AARRA
Originally Posted by C3 Stroker
Thanks for the suggestion. I called them yesterday, but the 800 cca does not fit the car, only the 720 cca will.
Old Sep 13, 2014 | 11:09 PM
C3 Stroker's Avatar
C3 Stroker
I believe the '79 takes a size 75 battery, but a size 34/78 may also fit depending on it's dimensions. If you have an O'Reilly's auto parts in your area, they may have what you need.
Maybe one of these.....http://www.oreillyauto.com/site/c/se...tte&vi=1041130
Old Sep 14, 2014 | 01:40 AM
LT1driver's Avatar
LT1driver
60s 427 with 11-1 compression only used 460 cca so don't see why you or anyone thinks they need 800cca, what you need is high reserve power, my $15 reconditioned battery start my 427 just fine thank you, no issues and it doesn't have 650cca.....just saying but to each their own.
Old Sep 14, 2014 | 01:26 PM
C3 Stroker's Avatar
C3 Stroker
If you live in the NE part of the country, N Jersey (the OP), or in Ohio (myself), it is cold more months than warm. You definitely need more CCA's. These batteries also have higher reserve power. It could make the difference between starting and not starting on a 10° morning.
Old Sep 14, 2014 | 02:08 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Do some studying on how batteries are rated. There is a LOT of goofy stuff out there. Some mfg's are changing the temp they rate at to get higher CCA's etc. Read the labels closely!
You have to think through what you need. Within the same size case, the only way to get more CCA is to add more plates....which means thinner ones. Those thinner plates are more apt to break/short to an adjacent plate over time. You don't want a deep cycle battery...they aren't made for starting. AGM's have their own quirks....they don't like heat.
Ck into the Odyssey brand for a pretty serious battery if you think you need it. They are the next level up from Optima "6 pack" design (Odyssey evolved from Optima).
Otherwise I can tell you that my 555" big block does just fine on an O'Reiley's flooded battery.
JIM
Old Sep 14, 2014 | 07:15 PM
Gordonm's Avatar
Gordonm
No need for anything special. I have run Die Hards, interstates and currently have an Optima. Never worried about CCA and I live down the road from. N Jersey. His car lives in the garage so it will not be of concern. Just get a decent battery that fits in the compartment and you will have plenty of cranking power.
Old Sep 14, 2014 | 10:54 PM
AARRA's Avatar
AARRA
That's exactly what I am going to do. I was concerned because the guy building the engine said minimum 800cca and if there is any problem, I don't want to give them an excuse to say it was because I did not follow their instructions. But, I've thought about it and will go with 720cca, particularly since I won't be taking it out in the winter.
Old Sep 15, 2014 | 01:19 AM
LT1driver's Avatar
LT1driver
if you are not running computer and electronics big cca or ca is not required, didn't have it in the cold north in the 60s, not needed now....i worked at a battery company until last years. beware of what is peddled...cold cranking amps or cranking amps, two different things and companies can be misleading on what they quote and Jim is right about battery design and construction......do your homework then chose.
To 800cca Battery
