Minimum overall engine to hood clearance
Old Sep 17, 2014 | 04:46 PM
Belgian1979vette's Avatar
Belgian1979vette
Default Minimum overall engine to hood clearance
How much clearance is needed between all engine parts and the hood to account for engine movement and such ?
Old Sep 17, 2014 | 07:46 PM
75sl48's Avatar
75sl48
I have about 3/32" and haven't had any issues
Old Sep 17, 2014 | 08:11 PM
gcusmano74's Avatar
gcusmano74
If you have the "locking" type motor mounts and they are in good shape, the engine won't move much.
I'd guess that 1/2" would be safe. Roll up SMALL diameter's of plumber's putty and stick them to the top of the air cleaner. Close the hood, reopen it carefully, and check your clearances.
Old Sep 17, 2014 | 08:24 PM
flyeri's Avatar
flyeri
Put the putty in a baggie. You can also use loosely balled up aluminum foil instead of putty. I used some modeling clay.
Old Sep 18, 2014 | 02:30 PM
Belgian1979vette
Those who read my posts know about the airboxes for my stack I'm building.
I have this issue on the right front edge. The engine is offset and the box just sits under the transition from the L88 bulge to the flat side of the hood.
I do not have much clearance now. Somewere around 3-4mm (1/8").
If I rework the box, I might be able to get 1/2" but that is the absolute max I can get.
To Minimum overall engine to hood clearance
