tank sender leak help
Old Sep 23, 2014 | 10:26 PM
LT1driver's Avatar
LT1driver
Default tank sender leak help
seals around the connection for wires to gauge leak, where can I get new ones that will work or what can i use to seal it.....thanks.
Old Sep 24, 2014 | 02:36 PM
loup68's Avatar
loup68
Army
I have had the O-ring seal leak and the soldered tube joint leak. First time that I have ever heard of the electrical connection leaking. Gasoline is hard to seal, it eats everything. I think that you are better off getting a new sending unit. Gas isn't cheap! Lou.
Old Sep 24, 2014 | 03:51 PM
Richard454's Avatar
Richard454
I just redid my tank-
Looking at my old sender - When you remove the nut & washer it looks like a phenolic type material washer.
It's yours if you want it- just PM your address. If you need the o ring gasket some how ended up w/ an extra one. I'll put it it in the envelope as well. You can't have the Permatex gasket sealer !!! It was like $13 since it's fuel resistant- and I recommend it.
Richard
DSCN4759 by richardhayes454, on Flickr
DSCN4760 by richardhayes454, on Flickr
Old Sep 24, 2014 | 05:30 PM
LT1driver's Avatar
LT1driver
Richard, PM sent, thanks.
Mike
Old Sep 24, 2014 | 07:32 PM
jnb5101's Avatar
jnb5101
You may have to thread the retention stud for a #6 nut. When I repaired mine, I couldn't get the speed nut to hold properly.
To tank sender leak help
