Re: Help - mild hicups & backfires during engine decel (14-Paul)
Look for vacuum leaks. "Backrap" is often caused by a lean condition. First place to look is headlights & heater/AC. Disconnect & plug all the vacuum hoses & check to see if the noise is gone on de-cel. If so, re-connect them one at a time.
Make sure you know what you are doing with regards to choosing the correct vacuum-advance port on the carb and setting up the distributor advance curve. (if not, I have one name for you - "Lars". Do a search)
Re: Help - mild hicups & backfires during engine decel (soundguy)
Check plugs and wires. Mine back fired after a hard accel when letting off the gas. Wires solved the problem.
Also check fuel mixture. The back fire (if I remember correctly) is gas burning in the exhaust. Too rich a mixture or incomplete burning will cause it.
Re: Help - mild hicups & backfires during engine decel (Surfer69)
Could be leaky exhaust manifold gaskets. Happen to me after header installation.
Check the entire exhaust system. I got some backfiring (popping) on decelleration when I had a broken front exhaust pipe. Also got some popping from a small leak all the way back near the muffler. MJ
