Tips on putting the radiator back in.
An auto mechanic friend of mine and I took out the radiator this weekend because it apparently had a pretty good leak. Love story short it took up about 4 hours. The lower hose connection kept getting hung up on the a-arm. We had to un-bolt the support bracket and tip it forward and it was still a nightmare. In what order would you guys re-install the radiator, shroud, shroud extender and fan?
Also, there was a bit of rust on the support bracket, and while it's out I was planing on hitting it with some rustoleum, whats some other things I should do while it's out.
Also also, is there a way to operate the head lamps and get them up and out of the way without vacuum?
Miles
DAVE
Miles
bolt the frame, radiator and shroud all together as one unit outside the car,
then install as one unit, bit heavy n bulky, but easy done with 2 people,
saves the cursing an swearing trying to get the shroud past the A arms.
took 5min and it was all back in.
then only put the bottom side frame bolts in, then lift top towards the front, slip the bottom radiator hose on and clamp.
lower back down, install the rest of the side frame bolts, done.
agree with all of the above, plus I would paint mark the location of the hood hinges and pull the hood off as it gives you some more access room.
Also, I would put some cardboard over the radiator fins on both sides to keep from damaging the radiator fins by accident.
Hope this helps.
Dave
Miles
Miles
been a couple of times on my 73, this seemed to work for me....
after draining rad, removing hoses & Fan
Remove hood
Remove top 2 bolts on rad support on each side
Remove 2 bottom (underneath) rad support bolts & Brace to header panel
Remove support to Rad mounting clamps
swing rad support vertical
separate shroud and pull rad out , may have to tilt to clear lower neck and control arm
installation is reverse
new Dewitts perfect fit (really is)
Things all nice and loose, new rad slid in quite easily
Runs much cooler now, even with the 454
I have been doing it that way for years you just need two people to do it.
Mark
I just put a DeWitts in my '71 BB. With the hood off, I took the original one out by separating the parts, but when I installed the new one, I put the frame, radiator, and shroud together and installed it as one unit.
It was much easier this way and except for removing the hood, (my wife helped) I did this by myself.
