You have access to a lathe....make some tapered holders that locate on the bearing races....the one for the inner bearing will have a spud on it to mount assembly in the jaws of the chuck....use a threaded stud from a mill hold down fixture set to put tension on the outer tapered holder then.....true the face of the hub to the bearing races. Doing this you will pretty much find you will never again have to shim a brake rotor for runout
how would you set up and center the front wheel hubs in a lath to true the face?
I have access to a lath, 3 wheel hub,s and books on how to use a lath but I would like to know from some one who has done it before.
If you're referring to the hub/rotor combo, the brake (lathe) equipment that is designed specifically for this task uses tapered cones (ID) that mount/center on the lathe shaft and then (OD) center on the hub bearings.
Thank you every one for your ideas. I like the one Solid LT1 posted this seems like the best way to get them true without problems.
New rotors typically have run-out right out of the box. I sold & turned rotors for a living and it didn't matter where the rotors were sourced... they had significant run out. Truing the hub is great start but you probably will find that any rotors you purchase will still have to be trued to get within spec.
