How to unlock a C3 without keys?
Old Oct 2, 2014 | 09:38 AM
ch3098's Avatar
ch3098
Default How to unlock a C3 without keys?
Hi,
I recently purchased a 73 coupe with both doors locked, windows up tight, and the keys in the ignition. I am looking for the least destructive method for unlocking the car. Thanks in advance for any suggestions!
Thanks,
Clayton
Old Oct 2, 2014 | 09:46 AM
sullyman56's Avatar
sullyman56
Originally Posted by ch3098
Hi,
Thanks,
Clayton
I have read that if you hit the t-top really hard in the area of the t-top locks that they will often unlock and you can then remove it. I've never tried it, but it sounds like it might work. If not, contact a locksmith. Good luck.
Old Oct 2, 2014 | 09:51 AM
mrvette's Avatar
mrvette
Coathanger with a hook on the end, and a bunch of patience, aiming for the lever on the latch, going to take a while, it's a touchy feely thing....
:toe tap:
Old Oct 2, 2014 | 10:09 AM
zuendler's Avatar
zuendler
If the key is in the ignition, i would take a long wire with a hook at it´s end and try to hook the key from the passenge side
Old Oct 2, 2014 | 10:57 AM
DonnieP73's Avatar
DonnieP73
Hi,
Thanks,
Clayton
You should be able to poke a long flathead screwdriver down between the window near the rear of the door.
There is a little tab that if you push down on will pop open the door.
Look for a tab like is in the below photo.
Donnie
Old Oct 2, 2014 | 11:13 AM
racer_357's Avatar
racer_357
Hi,
Thanks,
Clayton
I locked my keys in the car a while back and this is a bitch to break into. the t-top hit will only work if the latches are loose, mine were very tight.
Slim jim will work if you can catch the lateral lock rod. you also may be able to flip the t-top latch with a ridged flat metal strip. do you know how to pick a lock?
Old Oct 2, 2014 | 02:53 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I did that and it worked my keys were locked in and the engine was running, hit the top near the latch and the latch popped down. I now have locks on the latches. The trick is so old they sell locks for the latches
Old Oct 2, 2014 | 03:50 PM
ignatz's Avatar
ignatz
I have heard that you can kick in the rear window and the pot metal prongs will break off first. A last resort to be sure.
Old Oct 2, 2014 | 05:23 PM
71 Green 454's Avatar
71 Green 454
Originally Posted by '75
PM me if you didn't get it open yet, I have a video that may help.
Is that the video from ...Roger... where he uses an oil dipstick to open a C3?
https://www.corvetteforum.com/forums...ette-help.html
Old Oct 2, 2014 | 06:47 PM
7t9l82's Avatar
7t9l82
id like to see it but it seems honest people aren't allowed to see it.
Old Oct 2, 2014 | 07:05 PM
John 65's Avatar
John 65
Me too.
Old Oct 2, 2014 | 08:21 PM
AdamMeh's Avatar
AdamMeh
Well, this is now on the interweb forever.
Old Oct 3, 2014 | 12:10 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yeah, I'm just thrilled about that too.
Old Oct 3, 2014 | 11:34 AM
ch3098's Avatar
ch3098
Default Unlocked with no damage!
Thank you to all that offered advise. I was able to unlock my 73 last night with no damage. I even got it open without using the video. I studied the mechanism on my 69 that I am currently restoring and used the dipstick as recommended on the forum. Thanks again for those that offered help!
Thanks,
Clayton
Old Oct 3, 2014 | 12:22 PM
MotorHead's Avatar
MotorHead
If the lock on your door is the only theft deterrent then you are asking for trouble, a tow truck driver told me about banging on the roof 10 years ago when I phoned him to open my door.
I have 4 different devices and electronic circuits that make it impossible to start my Vette, even with the keys, the only way to steal it is tow it. Don't leave it unattended for than a few minutes. Sucks sometimes but that's the way it is
Old Oct 4, 2014 | 01:49 PM
Cavu2u's Avatar
Cavu2u
MotorHead
If you want to share your deterrents with a PM, I'd appreciate it. SoCal is, well, SoCal.
Steve
Old May 18, 2018 | 10:39 AM
LittleRed1980's Avatar
LittleRed1980
2nd Gear
I've just gotten my '80 out of storage after almost 20 years w/ hopes of spending a little quality time on it in the coming months.
I have the door key. But, I locked the door out of habit, like an idiot, when I trailered it. Now, the lock is frozen. I've sprayed in WD40 everywhere I can for a few weeks now, thinking I might eventually free things up w/o any luck. I've got mirrored-glass tops, and I've pounded on them about as hard as I think I can without shattering them w/o any luck.
I'm not sure how much force its gonna take to get this thing unlocked, but I'd sure like to try the dipstick trick I've been reading about on the forum if you someone can point me in the right direction.
Appreciate any help/suggestions. Looking forward to exploring the forum.
To How to unlock a C3 without keys?
Old May 18, 2018 | 11:48 AM
TimAT's Avatar
TimAT
Sort of- If they're glass tops, be EXTREMELY careful. Lean on the top over the latch and bump it with your fist. If the top is adjusted really tight on the latches the odds of success are very low. I have gotten into many of them like that, but I also broke a glass top one time too.
Old May 18, 2018 | 12:40 PM
MelWff's Avatar
MelWff
both doors are frozen? are you sure you have the correct key for the door?
Old May 18, 2018 | 12:46 PM
LittleRed1980
2nd Gear
Thanks. Yes. Years of not being cycled, I expect. I am certain I have the correct key for the door. Good question, though.
