Rear end
Old Oct 4, 2014 | 09:49 AM
diehrd's Avatar
diehrd
Default Rear end
Hi all I decided to do some more mods on my 1980
I have a good rear end BUT want to up grade the half shafts to the bigger stronger ones. Does any one have a good source and maybe even give me an idea as to the parts ill need ? to do the conversion
Old Oct 4, 2014 | 11:12 AM
Kid Vette's Avatar
Kid Vette
Fort Wayne Clutch and Driveline
Old Oct 4, 2014 | 11:44 AM
diehrd's Avatar
diehrd
Originally Posted by Kid Vette
Fort Wayne Clutch and Driveshaft
Thanks.
My confusion comes from knowing there are 2 different sizes one for a 4 speed which is heavier and uses bigger u joints however in my searches it sorta suggests my 1980 would have the heavier shafts to begin with but I am not sure.
If they dont have the heavier ones I will need the spindle connector the shaft and the stub axels
Old Oct 4, 2014 | 01:04 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by diehrd
Thanks.
If they don't have the heavier ones I will need the spindle connector the shaft and the stub axels
1980 & 81 manual transmission Vettes have the 1350 u-joint halfshafts. 1980 & 81 automatics have 1330 halfshafts. All 82s have 1350 u-joints.
Old Oct 7, 2014 | 12:47 AM
Gale Banks 80''s Avatar
Gale Banks 80'
The stock 1/2 shafts are as strong as any GM made. The 1330 u-joints are the weak point. To make the switch to 1350's You need new Yokes, 1/2shafts, and Axel Flanges. Toms differentials and Van Steel has even stronger parts.
To Rear end
