Low power at high rpms?!
Old Jul 31, 2002 | 03:43 AM
Justin79-L-82's Avatar
Justin79-L-82
Default Low power at high rpms?!
This has been an ongoing problem. Under WOT it has a very rough time shifting gears and boggs for a while then finally shifts gears after struggling for a bit. I thought this was a tranny problem at first but i have now come to think that it is either an ignition problem, fuel problem or timing problem. Does anyone have any suggestions?
Old Jul 31, 2002 | 03:45 AM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Low power at high rpms?! (Justin79-L-82)
maybe she isn't breathing well in the high Rs
Old Jul 31, 2002 | 03:53 AM
Justin79-L-82
Default Re: Low power at high rpms?! (Markm10431)
Breathing well at high rpms???????
Old Jul 31, 2002 | 07:15 AM
Matt Gruber's Avatar
Matt Gruber
tape a fuel pressure gauge to the windshield for a fuel test
Old Jul 31, 2002 | 05:49 PM
Justin79-L-82
Default Re: Low power at high rpms?! (Matt Gruber)
Should i be checking ingition parts? Cap, rotor, coil etc? Or is it more likely a tranny or fuel delivery problem?
Old Jul 31, 2002 | 06:13 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Have you tried adjusting the opening point of the secondaries? It sounds like the secondaries are opening too early. Do you have a q-jet? It will be easy with that. Do you know how to do it?
Old Aug 1, 2002 | 02:07 AM
Justin79-L-82
Default Re: Low power at high rpms?! (burners)
No I have not tried adjusting the opening point of the secondaries. I have the 795 qjet how do i do it?
To Low power at high rpms?!
