O/T - Best Radar Detector?
Old Jul 31, 2002 | 07:14 AM
shotgun_000's Avatar
shotgun_000
Default O/T - Best Radar Detector?
It never fails. I got another speeding ticket, as I went thru this little speed trap. The road was a 45 zone, except for one small section that is 35. This 35 section is so small, if you blink you will miss it. Guess where I got busted doing 50mph? :rolleyes:
I try to stay at a safe speed. The bad thing is, if you try to do the speed limit in places where it says 35mph, you honestly will get run over by these other drivers. But, these Highway Patrol officers(No offense to anyone) seem engaged in a competition to see who can pull the most people over, and get their jollies from doing so. Meanwhile, truckloads of dope roll on past where I am pulled over.
So, I need to fight back. I've had cheap radar detectors before, some that didn't even go off after passing the radar gun. These same detectors were only good for finding grocery stores. :lol:
So, what is a good radar detector? I'm willing to spend the bucks on it, if it really works. Also, what about the laser guns? Will the newer model detectors give any protection from the laser guns. Thanks for any advice or comments!
Old Jul 31, 2002 | 08:53 AM
Tom73's Avatar
Tom73
Default Re: O/T - Best Radar Detector? (shotgun_000)
Valentine 1, best on the market. Escort Passport 8500, very good, second to only the V1. All the rest - forget them.
Get a V1. But it is expensive. If you cannot afford the V1 get the Escort. Don't even consider any of the others.
Valentine 1 at http://www.valentineone.com/home.asp
Escort at http://www.escortstore.com/
Both have a 30 day no questions money back guarantee, so order both, try them for a couple of weeks and keep the one that works best for you and return the other.
tom...
[Modified by Tom73, 6:58 AM 7/31/2002]
Old Jul 31, 2002 | 09:03 AM
Corey_68's Avatar
Corey_68
Default Re: O/T - Best Radar Detector? (Tom73)
:yesnod:
Old Jul 31, 2002 | 09:20 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I bought an Escort Passport years ago and still use it. At the time it was rated to be the best. Don't remember what model. It usually gives me plenty of warning against radar. If they're using laser, I'm dead in the water. :(
[Modified by 1970 Stingray, 9:17 AM 7/31/2002]
Old Jul 31, 2002 | 09:57 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I've been hearing ads on the radio for a unit I think is called the "Phaser"??? The ad says that they will pay your speeding ticket if you get one while using the thing, which is probably :bs They also claim they are sooooo good that they are illegal in several states! Hmmm, I think ALL detectors are illegal in these same states.
With the new laser guns the only way to avoid a speeding ticket is not to speed (excessively.)
Old Jul 31, 2002 | 11:50 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Valentine One, hands down the best detector you can buy. Many times I will get warnings 2 miles ahead, usually I at least get a 1/4 mile warning. It will warn you of laser but usually you are toast if it goes off. Although it may give you a little warning. I've never been hit with laser.
Old Jul 31, 2002 | 11:51 AM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: O/T - Best Radar Detector? (burners)
I love my Uniden.
Old Jul 31, 2002 | 11:57 AM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
St. Jude '03-'04-'05-'06-'07-'09
In Illinois, and most states, speed traps are illegal. Check your states law. In most states a speed reduction warning must be posted prior to the actual new lower speed limit sign. In Illinois the reduction sign must be 500 feet prior to the new lower speed limit sign. They generally say "SPEED LIMIT REDUCED AHEAD" or "SPEED LIMIT 35 AHEAD" etc. If there is no reduction sign and you get busted within 500 feet of the new lower speed sign you win in court! Of course if you passed the 35 sign and 500 feet later still hadn't slowed down then shame on you. I'd check your law and fight it.
Old Jul 31, 2002 | 12:58 PM
gkull's Avatar
gkull
Up till this Uniden I always used Bell. If you really read up on the top of the line models they are all pretty close. I get warnings in Ka so far away that you start wondering where they are. Mine was going off for nearly 20 minutes and I was starting to think that it was broken. But then I finally caught up to him driving down the freeway at 85 turning it on and off at oncoming cars. I was miles behind him at first and his gun was pointed away. That's sensitive enough for me
Old Jul 31, 2002 | 01:09 PM
trw's Avatar
trw
Wife in the passenger seat. :D :D
"Your going too fast again." "Didn't you see that speed limit sign."
Terry
Old Jul 31, 2002 | 01:24 PM
gkull's Avatar
gkull
Default Re: O/T - Best Radar Detector? (gkull)
I was going to add that my last Bell 985 was near $400 and it died while under the 2 year warranty. So I exchanged it for a nearly $300 Uniden. but now out on the web I can't find my same model.
I'd get on cunsumer reports and get the best bang for the buck.
[Modified by gkull, 11:34 AM 7/31/2002]
Old Jul 31, 2002 | 01:27 PM
Tom73's Avatar
Tom73
Here is the Car and Driver radar detector test:
http://www.caranddriver.com/xp/Caran...dar%20detector
tom...
Old Aug 1, 2002 | 04:49 PM
Tennis Bum's Avatar
Tennis Bum
Just got a new V1 (for my 60th B-day), and hardwired it today. Don't know if its the best, but after just two days of trolling, I'm a believer. Two features I especially like are the dual volume controls, and the directional arrows. The ergonomics are great, and the mounting system seems very solid. It's been said many times by others on the forum, but I'll add one more...those arrows are GREAT! My only gripe (so far) is that the "advanced logic" mode doesn't totally eliminate the "noise" from door openers and alarm systems in urban/suburban areas. On the open road, however, there is little or no noise.
Old Aug 1, 2002 | 09:01 PM
shoptek's Avatar
shoptek
I got a Passport 8500 about 3 months ago, and so far so good. The area I live in is swarming with city motorcycle units with radar. They usually stalk the same 2 or 3 places and I always get at least a 1 1/2 mile warning when the are ahead of me on a straight road, and about 1/2 to 3/4 mile warning when they are around a curve.
The ONLY time I feel that I could have been nailed (I wasn't speeding though) was in Georgia on I-95. 1 officer was using a concrete post to steady his laser gun, and 10 GA. Highway Patrol officers were in there cars waiting to pounce.
When the Escort goes off for a laser alert, it is LOUD, OBNOXIOUS, URGENT ETC.
The good folks at Escort owe me a new pair of underwear and an upholstry cleaning :lol:
[Modified by shoptek, 8:02 PM 8/1/2002]
To O/T - Best Radar Detector?
