Replacing t-10 transmission gears
Old Oct 8, 2014 | 12:49 PM
jaybird81's Avatar
jaybird81
Default Replacing t-10 transmission gears
I saw on a sight for identifying BW T-10 transmission that they had different gears. The one in my 81 Vette came out of an 80 and has the following gears 2.88 1.91 1.33 1.00 2.78. however in an 80 or 81 Camaro you could have 3.42 2.28 1.46 1.00 3.51. So my question would be is it possible to replace the gears in my trans with a set of gears for the Camaro trans?
Old Oct 8, 2014 | 03:34 PM
dochorsepower's Avatar
dochorsepower
Try searching for the recent post about this. The 3.42's are prone to breakage if used hard. The 2.88 should give you all the first gear you need. I run 2.64's with a 3.08 rear.
Old Oct 8, 2014 | 03:46 PM
Garys 68's Avatar
Garys 68
Yes, it's possible on a super T10 to swap the gears, but you would need to swap all internals. That would probably be $600+.
As pointed out the 3.42 gear set is also the weakest.
I bought a 3.42 T10 out of an 82 Camaro locally for $100, that may be a better route if your current trans is good. They're not very popular because of strength. If you can find an 81 Camaro 904 iron case with the 3.42 gears, they're tougher, but you'll pay a premium.
Old Oct 8, 2014 | 04:06 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Multiply your first gear ratio by the rear end ratio. 10:1 is ideal for drag strip, lower than this will be difficult to hook. If for daily driving, total first gear ratios will become granny gear ratios requiring shifting to second before you've even gotten out of the intersection. IMO, reasonable corvette first gear total ratios are in the range of 8 through 10.5 to 1. I'd not even consider a 3.42 first gear ratio for a corvette.
Old Oct 8, 2014 | 04:31 PM
jaybird81's Avatar
jaybird81
See this is why I was asking. The 2.88 first gear I have with the 2.87 rear gives me an 8.2 rear end ratio. 3.55 rear gear with my tranny gets me to 10.2 which I guess is where I should be. If I switched to the 3.42 with my 2.87 rear I get 9.8.
Old Oct 8, 2014 | 05:28 PM
Garys 68's Avatar
Garys 68
I guess the question is what's your goal?
I'm using a 3.42 T10 with 2.73 rear in my 5.3 LS swap 72 Olds cutlass. That car is a couple hundred pounds more than a vette. I wanted a decent 1st gear but would be mostly highway driving. The 2.56 Muncie I originally had was too tall.
The first on the T10 is kinda short, I'm actually contemplating a 2.56 rear with it, a little better on the highway too.
The spacing is kinda wide, which is not an issue with the 5.3. The compression and cam on LS motors has a great torque curve.
And I wouldn't even consider driving it too hard off the line.
You're kinda stuck with that combo. The 3.42 is better for acceleration, but you probably cant use it hard enough to do what you want.
A TKO500 would be an option, but you would need to change your rear to have a usable OD.
No simple, cheap solutions. Wait and see if you can find a cheap used 3.42 T10. But be sure to check internals.
Old Oct 9, 2014 | 08:33 AM
jaybird81's Avatar
jaybird81
Gary, good point. The car has a mildly built 350, maybe 350 HP. I use the car mostly for around town driving on weekends. I hope to take it to a track once or twice a year, and would like the off the line acceleration, but didn't want to put a 3.55 rear in to effect the highway driving I occasionally do. I thought going with the 3.42 first gear in the tranny was a decent option. Better acceleration off the line, but once in 4th it would be the same as now.
Old Oct 9, 2014 | 08:54 AM
Garys 68's Avatar
Garys 68
I personally would never take a 3.42 to the track. If you kill a gear, you'll probably distort the case. Now you have 75lbs of steel and aluminum.
Your best bet might be to find the 3.42 T10 in the iron 904 case. They were advertised as a "drag racing" gear box back in the day. The gears are no stronger, but the case is less prone to distortion.
There's one on ebay now, but has the 2.88 gears in it. I'm guessing I know what happened to the original 3.42 gears.
Asking prices for the 904 trannys generally run about $750 used. Then plan on $200 for rebuild kit with synchros, torque lock sliders, etc.
BTW, if you have a relatively low compression stock 80 motor with any cam upgrade (increased overlap), you'll have a narrower torque peak and hate the 1st to 2nd gear spacing in the 3.42.
Old Oct 9, 2014 | 09:07 AM
jaybird81's Avatar
jaybird81
I have a higher than stock compression 10.25:1 motor with a rough cam. The tranny now is a super t-10 out of an 80 vette not sure what the case is for that. So looks like the general opinion is that no one sugests going with the 3.42 first gear. I guess that option should be removed from my list....
Old Oct 9, 2014 | 09:33 AM
C3Hawk's Avatar
C3Hawk
I had the same thought process a while back, figuring it would be a decent relatively inexpensive compromise. Aside from the spacing, the biggest issue for me was the low torque rating of the T-10 with the 3.42 first gear. If you look at the Richmond catalog, it has the lowest rating of the bunch at 286 ft-lbs. (at least for the non iron-cased ones.). This just won't do it. Like Gary pointed out, you will get your magic number of 10, but you won't be able to drive it hard enough to make use of it.
To Replacing t-10 transmission gears
