Upper Control Arm bolts - Help
Old Oct 10, 2014 | 06:13 PM
Teem66's Avatar
Teem66
Default Upper Control Arm bolts - Help
1980 L48 Auto
I've watched every video I could find on removing the front suspension. Unfortunately the ones I've seen have the body off the car. My problem is the upper control arm bolts, passenger's side, that hold the bushing bar to the frame. I know about slide hammering the bolts out once I remove the nuts. What I'd like to know is what size are the nuts and how did you get them off (special wrench, swivel socket, magic, etc). Any help/suggestions are greatly appreciated. BTW, driver's side is already disassembled.
Old Oct 10, 2014 | 06:58 PM
labhound's Avatar
labhound
On my '74 it was easier to get to them by removing the dust cover, I replaced them anyway, don't remember what size.
Old Oct 10, 2014 | 07:14 PM
MelWff's Avatar
MelWff
how about putting them in a bench vise?
Old Oct 10, 2014 | 07:32 PM
RickyBerg's Avatar
RickyBerg
The bolts are like wheel studs just forced in on tiny splines.
If you put on the nut just enough to cover the threads a couple of gentle taps wih a hammer will get then lose.
Old Oct 11, 2014 | 11:24 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I believe the nut is a 7/16 - 14 But it sounds to me like the stud is turning when you try to remove the nut.
Hopefully the splines on the stud are the only thing allowing it to slip and you don't need to repair the hole in the frame.
Old Oct 12, 2014 | 01:07 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Nuts for the upper control are shaft should be on the engine side. Bolt heads outboard. Nuts are 5/8 wrench size IIRC. If they are installed correctly all you'll need is a 5/8 open end wrench to remove them.
If the bolts are installed backwards(head inboard) you'll need a deep socket and a universal joint to get under the A arm to hold the nut. then turn the bolt head to remove them.
If the bolts are installed correctly the bolt should not spin as the section under the head is splined to provide a interferrence fit into the frame.
If it does spin just use a 5/8 wobbly socket to hold the head.
Get new replacement bolts. Doorman replacements have a bigger spline so they grip a hole thats been buggered by a spinning bolt
Old Oct 12, 2014 | 07:34 AM
Belgian1979vette's Avatar
Belgian1979vette
A partnumber for that bolt might be nice.
Old Oct 12, 2014 | 09:05 AM
0Willcox Corvette
Former Vendor
Old Nov 2, 2014 | 11:33 PM
darrentpi's Avatar
darrentpi
Originally Posted by Teem66
1980 L48 Auto
Use a c clamp, and a 5/8 deep socket. Put the socket on the inside of the frame where the bolt head is, lift the control arm up as high as you can, and slip the c clamp around and over the bolt and socket. Tighten her up and give it a light smack with a hammer, and it will let go. It is splined just like wheel studs. Do not try to undo them with a socket, as you will ruin the pressed spline portion..
To Upper Control Arm bolts - Help
