OK Where do these Go?
Old Jul 31, 2002 | 03:59 PM
micks69's Avatar
micks69
Default OK Where do these Go?
I have headlight washers and would like to know what these wires should connect to? :confused:
http://temp.corvetteforum.net/c3/micks69/71502_022.jpg
[Modified by micks69, 2:59 PM 7/31/2002]
Old Jul 31, 2002 | 04:51 PM
honaker's Avatar
honaker
Default Re: OK Where do these Go? (micks69)
I just looked it up in the Haynes repair manual. I know it's not the greatest source of info, but hey, it was sitting on my desk.
I think i found what they are hooked up too however, it don't think the info will help unless you are looking at the same diagram that i am.
Any way, it appears that on lead is supposed to go back to the fuse block, the other is supposed to be connected to a wire going to a 3 pin connector(the yellow wire if it's still stock) going to the wiper motor right be side it.
Please don't wire this up acording to me. Get a diagram to go by. :smash:
Old Jul 31, 2002 | 10:32 PM
stingray72's Avatar
stingray72
That is a 69 ONLY headlight washer pump, and is no longer available. It is also a hard item to find, so be careful with it.
I don't have a 69 wiring diagram, but I wanted to ask if your windshield washers work? PERHAPS those two wires connect to the two wires for that pump. I am referring to the ones that connect under that small "hood" on the front of the wiper motor plastic cover.
George
Old Jul 31, 2002 | 10:45 PM
micks69's Avatar
micks69
George,
It looks like the hose that comes out the end goes to the front of the car where the headkight washer (squirters) are. :)
Old Jul 31, 2002 | 10:58 PM
stingray72's Avatar
stingray72
Thats right. The rubber hose runs along the fender skirt, up to the headlight washer nozzles. That secondary pump is activated by the same switch that turns on the windshield washers. While fluid is squirting onto the windshield, fluid is also squirting onto the headlights.
Do your windshield washers work?
George
To OK Where do these Go?
