Do I need a new A Arm bushing shaft?
Old Oct 12, 2014 | 08:22 PM
Teem66's Avatar
Teem66
Default Do I need a new A Arm bushing shaft?
1980 L48 Auto
The shaft in the foreground is the A Arm bushing shaft from my car. Compared to the Upper Control Arm bushing shaft in the background of the picture the A Arm bushing is pitted. Is the smoothness of the shaft critical to the bushing function? Should I buy new A Arm shafts, attempt to smooth the pitting or just install new bushings on the existing shafts?
Old Oct 12, 2014 | 08:31 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Shouldn't cause a problem.
Once properly installed the bushing collar should not twist on the shaft.
The end bolt drives the collar teeth into the shaft shoulder and there it stays. The only time it needs to twist/turn on that portion of the shaft is when you initially set the vehicle on the ground to establish the unsprung position for the bushing. At this point you tighten the end bolt to specifications and it should no longer move.
Old Oct 12, 2014 | 08:51 PM
Teem66's Avatar
Teem66
Fred, thanks for the quick and informative response. I wondered why those teeth were there. You just saved me some money.
To Do I need a new A Arm bushing shaft?
