Pulling the trigger on AFR's
Old Oct 13, 2014 | 02:05 AM
OMF's Avatar
OMF
Default Pulling the trigger on AFR's
I've decided to go with some AFR 195's 65cc heads for my 406.
The question is should I go with the straught plug 1034's, or go with the angle plug 1040's. Back in the day there was HP to be found with the angle plugs, but is there any benefit to angle plug heads these days??
How about fitment around the headers, (I've got headman elites) any problems with plugs or plug boots burning.
Any other knowledge out there......
Old Oct 13, 2014 | 02:30 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Good question, for myself I'm looking at the at the 1036 straights or the 1038 angles. Also have the Hedman headers, but need to lower compression and better flow so I can push the air in. Like the idea of the angles but wonder about burning the wires. Right now running Dart Pro 1s straights with no problem. From the research I've done the angle provides a better combustion due to a better plug tip location. Not much help was I? T
Old Oct 13, 2014 | 07:08 AM
gkull's Avatar
gkull
Unless AFR has changed the location of new casting angle plug heads they are not the most header friendly head on the market. I had to alter my hooker s/c on one primary. Where my previous Dart angle plugs had no problem.
Your other problem will be having to go to a single plane intake to match up port size and your header size really needs to be at lease 1 3/4.
Read the specs on those AFR head port sizes.
I use 210cc on my 383
Old Oct 13, 2014 | 08:49 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I would just use straights....and as GKull mentioned..unless you're keeping RPM way down...I'd look at a larger set of heads. 406" is a lot of cubes to feed.
Don't get me wrong....195's will do OK....but........
JIM
Old Oct 13, 2014 | 08:57 AM
Gordonm's Avatar
Gordonm
I also ran 210s on my 383. Fairly large solid roller cam but I took it to 7000 rpm quite a lot. For a 406 I would go with the 210s. As said also 1 3/4 headers are a must for that many cubes to get the most out of it.
Old Oct 13, 2014 | 09:18 AM
bluedawg's Avatar
bluedawg
I got straight plug 195s on my 400, fit headers fine, running an rpm air gap now and 1.625" headers, am going single plain and 1.75" headers this winter, kinda wish I'd gone 210s though.
DO MA NEU!
Old Oct 13, 2014 | 10:47 AM
71scgc's Avatar
71scgc
210s with straight plugs on my 400 build.
Carter
Old Oct 13, 2014 | 10:57 AM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
210cc straight plugs AFR on my 406 with Hookers. With 65cc chambers, you're CR is going to be in the 11s negating pump gas, I think.
Old Oct 13, 2014 | 03:02 PM
C3 Stroker's Avatar
C3 Stroker
210cc Eliminators on my sb427. I have the 75cc chambers, which bring the C.R. to 10.5. This works well with pump gas. Also, the newer style heads have a slightly different plug location improving the angle, giving more room for header clearance (I have angle plugs and Hooker Super Comps 1¾" tubes)....plenty of room.
Old Oct 13, 2014 | 04:01 PM
Robert Thomas
Army Hoist Operator
Mine are 75cc heads, too, and I use 91 octane (only thing available reliably here). I manage the AFR (wide band system) and timing carefully.
Old Oct 13, 2014 | 04:42 PM
StraubTech's Avatar
StraubTech
Street car and not worried about time slips at the track...just want stop light to stop light acceleration....195's.
Old Oct 13, 2014 | 04:43 PM
pauldana's Avatar
pauldana
I'm running straight plug AFR 220 competition ported on my 427... and I wonder if I went big enough?!?!?
Old Oct 13, 2014 | 04:46 PM
StraubTech's Avatar
StraubTech
You haven't harnessed what you have now....I think your just fine.
Old Oct 13, 2014 | 05:00 PM
pauldana's Avatar
pauldana
i will:-)
Old Oct 13, 2014 | 05:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had Edlebrok Vic Jrs 215cc ( cc'ed to 219 ) on my old 406ci. The torque curve was flat as a table top with close to 400ft/lbs @ 2000RPM at the wheels. I would not go anything less than 210's, especially if they are not too much more coin.
Old Oct 13, 2014 | 06:37 PM
OMF's Avatar
OMF
Thanks for all the replys guys. It sounds like I should be considering larger heads.....but I'm kind of worried about killing good torque and street manners.....just a street car with occasional days at the track.
Old Oct 13, 2014 | 06:43 PM
OMF's Avatar
OMF
Hey there Robert, thanks for the reply. My engine has the 15cc dished pistons, so compression was calculated at 10.3 with my 64cc vortec heads.... I think I'll be all right with the 65cc heads.
To Pulling the trigger on AFR's
Old Oct 13, 2014 | 08:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youre not going to kill torque at all 406 can handle plenty
Old Oct 13, 2014 | 10:07 PM
cooper9811's Avatar
cooper9811
I was running a 406 with AFR 195 (1034) and a dual plane intake - street driver only, had plenty of torque where I wanted it. It was really strong from 2000 RPM up, and had plenty to get me going off idle too. Loved every minute of it until a roller rocker C-clip gave out... but that's another subject.
If you race, go bigger, but the 195s will be fine for light-to-light acceleration and highway driving. I also have a set of the same heads on my 383 (which is now back in my car so I can drive it) - great heads for either combination IMO.
Old Oct 14, 2014 | 12:58 PM
Kacyc3's Avatar
Kacyc3
What cam are you planning to put in? AFR recommended 195's to me for my 406 with a 234/244 @.050 .480/.510 112 cam
