brakes
my 79 barn find needed calipers, pads, a thorough flush of brake fluid, and a good cleaning of everything on all four corners but looks pretty spiffy now! not sure if you are aware of the brake bleeding sequence, but you should search for it. left rear, right front, right rear, drink a beer, or something. i followed the procedure and had/have no issue, firm pedal with correct travel. no leaks.
like most here i'm on a budget and progress as funds allow. but rather than replace the one rubber brake line, i probably should have sprung for the braided steel lines. as i knock items off my to-do list, braided lines are popping up a little higher on my priority list.
i also repacked the front wheel bearings (a recommended 30K mile service). used solvent and got them spotless then bought a bearing repacker (local autoparts store for less than $10). i used grease that meets the GM spec in my '79 service manual, still easily available. follow the procedure for setting up bearing preload and you'll have no problem. replace the cotter pins with the correct diameter, i replaced the weenie ones the PO had in there. i also replaced the seals.
every once in awhile i'll check the temps of the front and rear wheel bearings and rotors, just to make sure all is well. should be warm-ish, not hot.
rear wheel bearings are another story, luckily the PO had the entire parking brake assemblage (cables, pulleys, pads, etc) replaced, along with rear wheel bearings and spindles.
plenty of help here. i searched for 3 years before i found my car, lurking here a lot.
Having said that, I agree with Easy Mike. Do not replace rotors that are within spec. You will probably introduce runout that isn't there now.
