77 trailing arm
Old Oct 19, 2014 | 10:40 PM
hazelrigg74's Avatar
hazelrigg74
2nd Gear
Default 77 trailing arm
I'm new to vets and got a question and need some input. 77 Vette I was getting a pop noise coming from the rear end. I couldn't find anything when I jacked it up. Notice while in the air I started and put in gear and the passenger side was trail arm was jumping like the was something out of balance. I put jack under the shock support and start raising it up more pressure I put on the less it wanted jump. What could be causing this. Any help would be nice.
Old Oct 19, 2014 | 11:41 PM
briankeery's Avatar
briankeery
Welcome to the forum, I remember my first post. You don't want to run your car while on jack stands. The suspension hangs, and causes the u joints to bind - that's why it stopped as you jacked up the trailing arm. Check your differential fluid level; if low or dirty, replace it and add GM posi additive. Then do some low speed figure 8's to work the fluid into the clutches. See if this works for you.
Old Oct 20, 2014 | 12:36 PM
hazelrigg74
2nd Gear
Thanks for the input. While on jack stand is the short shaft suppose tight against the axle when bolts are out or gapped about 1/2 inch. Mine is gapped. Is there suppose to be play in the yolk it looks like it moves a 1/4 to 1/2 with the short shaft out.
Old Oct 20, 2014 | 12:59 PM
briankeery's Avatar
briankeery
Like many here; if your rear end has had no major service since new, your stub axles have worn at their ends to the point where the c-clips may not be holding them in place any more. A major service is probably due.....but be careful how you proceed at this point of ownership. First off, if this car is to be used as a weekend cruiser and stored six months of the year as mine is - with maybe 1000-1500 miles a year put on it, then maybe you don't want to go there until absolutely necessary. If you're going to be undertaking a major frame off, then dive right in. You'll get a lot of responses to your dilemma, but first see if a fluid change has any effect on the issue. It's cheap and relatively easy to do. You need to suck the fluid out of the filler hole, as no drain plug exists. Your local auto parts store should have a hand pump to do this. I also recommend picking up some service literature, namely the Assembly Manual (AIM) and Service Manual (the bible the mechanics used when servicing the car). These are invaluable, even if you choose to have a mechanic do all the work, since you'll understand what the process is you're being charged for. Good luck.
To 77 trailing arm
