Floorboard protection material?
Then I put down insulation and new carpet.
Also did you replace the padding as well? That's the stuff that really appears to be the culprit behind why the water was held under the carpet so well. That crap looks like a sheet of compressed dryer lint, and it holds water really well. I'm thinking it might be better (and dryer) to go with a thin sheet of foam rubber or something similar.
As far as padding - foam will hold water too - and not last as long.
The cure : keep the water out.
They sell similar backing for residential carpetting - for installation
on cement floors and other damp areas. This stuff will hold up
better than foam - IMO.
Re: keeping water out - I just noticed two days ago that the drainage
hose for the rear deck vents was broken. Actually, I think it was torn, since
it was still soft rubber. Any time it would get wet the vents would drain
directly into the car (I called it a bath tub). The hose is right behind the
passenger seat below the rear window.
The carpet padding that I'm speaking of is NOT the composite/recycled
polyurethane foam padding known as "rebond". It is very similar to the
original jute backing that you took out, known as fiber or jute padding.
Various pad types are described here:
http://www.carpetguru.com/pad200.htm
The Frothed Foam pad that they describe here sounds good - CLOSED cell,
so no water gets in !! :) Is this the stuff you are talking about ?
Sorry if it is - I assumed you meant the most common rebond padding.
On one last note : I learned a trick from pulling my Buick carpet up. They
use the jute padding, but it has a heavy tar-paper like layer glued on top
of the padding, which keeps "normal" water from soaking through the
carpet and into the pad.
:seeya
