cam
Old Aug 1, 2002 | 02:04 PM
ALIEN's Avatar
ALIEN
Default cam
I recently had some work done under the hood, and the mechanic say that he felt someone has worked on the engine before and put in a different, or bigger cam. Is there anyway to check this out without a tear down? :flag
Old Aug 1, 2002 | 02:32 PM
Gordonm's Avatar
Gordonm
Default Re: cam (ALIEN)
The only way would be to put a dial indicator on the valve retainer and check the lift. Even this is not a real good way. But if the lift is a lot higher than stock a new cam might have been installed. Other than that it would be kind of hard.
