Help 1982 Corvette CFI
Old Oct 26, 2014 | 07:09 PM
82corvettecfi's Avatar
82corvettecfi
2nd Gear
Default Help 1982 Corvette CFI
I have an 1982 Corvette Cross fire injected everything original wash the car go to start it turns on runs for a little then turns off do you know what the problem can be ? Thank you
Old Oct 26, 2014 | 07:53 PM
F22's Avatar
F22
Sunday, World Series, maybe an answer later.
Old Oct 26, 2014 | 08:25 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
A light bulb turns on and then turns off, not a car.
Old Oct 26, 2014 | 09:10 PM
82corvettecfi
2nd Gear
Let me know with correct answers if you have any ideas what cause the problem ?
Old Oct 27, 2014 | 12:18 PM
doning's Avatar
doning
I would start with the plugs and see if you have spark. Also, see if your fuel injection system is working and see if your engine is getting fuel. Your car also has a computer. There may be an issue with that too. You need to start somewhere. Good Luck.
Old Oct 27, 2014 | 01:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...wash the car go to start it turns on runs for a little then turns off do you know what the problem can be?...
I'd say you got it wet. Have you checked for moisture under the distributor cap?
Old Oct 27, 2014 | 11:36 PM
wombvette's Avatar
wombvette
ANSWERS PRICING
ANSWERS $.50
ANSWERS Requiring Thought $1.50
ANSWERS Correct $3.00
DUMB LOOKS are still. FREE
Old Oct 28, 2014 | 12:50 AM
Drawmain's Avatar
Drawmain
Check for fuel delivery first. Could be a simple as a clogged fuel filter, or a bad fuel pump. If those check out move to checking for spark, check the cap and coil and all wires and plugs. Did your Check Engine light come on at all? If so, check the codes.
To Help 1982 Corvette CFI
