82 Blower
Old Oct 30, 2014 | 12:48 PM
dawn90jay's Avatar
dawn90jay
4th Gear
Default 82 Blower
Is there any way that i can put a blower coming out of the hood without converting over to a carburetor?
Old Oct 30, 2014 | 02:30 PM
7t9l82's Avatar
7t9l82
sure, but not with the factory Fi unit. and why would you even try. you would need to build a different engine to get Any performance from it.
Old Oct 31, 2014 | 01:41 AM
Jamess411's Avatar
Jamess411
I did that upgrade…..costs about 8 grand…that was with a 500hp stroker engine already built for the blower. 3 g for the blower….4 g for the injection and computer stuff…about a grand for the misc other stuff including the meth injection add-on.
Old Oct 31, 2014 | 01:59 AM
Jamess411's Avatar
Jamess411
All the computer stuff and ignition box plus distributer, $3000
Injector hat and injectors, $1700
Blower, $2500 didn't use the carb plate.
Twin motor pump and good billet filters along with a high pressure regulator, $700
And POOF!!! You have an injected blown engine….those prices are not including all the braided lines, fittings,electrical connectors and special plyers to make the connectors, throttle linkage, time and counless trips to everywhere to make it all fit together.
Old Oct 31, 2014 | 03:03 PM
76Rat's Avatar
76Rat
And it all get done in a half an hour or the slow guys get it done in an hour. I should know, I see it done on TV all the time.
Old Oct 31, 2014 | 04:32 PM
73C34me's Avatar
73C34me
Awesome. More pocs please
Old Oct 31, 2014 | 09:16 PM
Jamess411's Avatar
Jamess411
Two of the reasons for going EFI were to put the injectors in the hat to keep the visibility restrictions down to a min and second so that I can boost enough to get up into the 800s hp range and still be able to stop at any gas station for fuel. The Holley water/meth injection takes care of cooling down the intake charge and boost octane points to make that all work.
Old Nov 1, 2014 | 04:22 AM
Jamess411's Avatar
Jamess411
Just barely peeking out lol
Old Nov 2, 2014 | 07:13 PM
Wrecked82's Avatar
Wrecked82
There is this turbo vane thing you can put in your air cleaner, but I do not know if they are made anymore. Demand probably exceeded supply.
Old Nov 2, 2014 | 08:14 PM
7t9l82's Avatar
7t9l82
turbo vane thing
Old Nov 3, 2014 | 06:34 PM
hugie82's Avatar
hugie82
I remember the early 90s Chevy/gmc trucks that whipple made a small blower that worked very well using the small throttle body. I always thought the positioning of the TBs doesn't matter except for throttle linkage and fuel lines if you were to sit the TBs inline on top of a small 144-142 blower. After that it will be test tune with injector size, pressure and timing curve. Custom proms are possible but when it's all said and done an aftermarket FI might end up being cheaper. Most likely performing better.
A side note, there was a guy I found on the inter web that turbo charged his CFI . It didn't cost much but it was many hours fab bing the air cleaner. Sealing it up and turbo plumbing. He did it with no ECM mods. Just fuel pressure and injector size.
Old Nov 3, 2014 | 06:56 PM
JimLentz's Avatar
JimLentz
Performance, priceless!
Old Nov 5, 2014 | 09:03 AM
Jamess411's Avatar
Jamess411
Originally I wanted to build a twin turbo engine. Fitting everything under the hood and the turbos just in front of the firewall on each side…the deciding factor was that the fenders do not come off and would be a huge pain in the butt to try to fab everything inside while leaving over the car lol. If I had a tilt front end at the beginning that would have been my route. Maybe next time )
To 82 Blower
