Testing wiring harnesses
Then put one fuse back, shut the switches off for whatever is on the fuse,and again crank up the current limit and check for zero current. Then you can turn on whatever as long as it doesn't draw more than 10 amps (the power supply limit).
Keep checking one fuse at a time.
Headlights and motors will need more than 10 amps but your lab power supply should automatically cut out at 10 amps or whatever it's capability is.
This is the way that I thought was the safest for checking out circuits particularity if there is harnesses just hanging there.
With the lab power supply, you always know what the current draw is..that's the advantage of doing it this way.
Others may have better ideas.
I did this for my 73 after a body off with harness hanging out, but before hooking up a battery.
Steve L
73 coupe since new
All I have is a 120v ac to 12v dc converter and a volt meter. however the harnesses are all hanging, just started to fit the a/c ducts to see how they fit. can these be used effectively?
Bill
Also I checked all of the pins at the far end of the harness, in case the wires were shorted to each other. You should only have voltage on the wire that you are applying voltage.
Steve L
73 coupe since new.
Best $130 bucks I ever spent (get the III, that's what we have, not the II). It hooks up to the battery and has a very long cord and a built in ground clip. You can apply 12V or Ground with the rocker switch (remember, all the dash lights are always hot and it takes putting a ground to the outer metal ring, to make them come on). It also tells you, whether or not, if you even have a circuit to begin with! All you have to do is touch the probe and the green led will come on, telling you that you have a circuit.
Oh, and it also has two white LED's to light up the area your working in. If you have a problem with let's say a tail light, it takes seconds to put power to it, and then go back until you find where the voltage stops. Easy! Checking fuses? Just brush the probe tip across the fuses and you'll get a test tone and a light on the good ones and nothing on a blown fuse. Takes five to ten seconds. Love, love, love my Power Probe and if you don't have one, you should get one. When I installed my dash harness, that's what I used to check it, as I went along as well as checking the dash lights, right before I buttoned it up.
Prepare to leave your other tools on the bench. Once you connect the Power Probe III to your car battery you will have access to an amazing variety of diagnostic functions.
With the press of a switch you'll have an instant hot lead or ground lead. Use the probe tip and ground lead simultaneously to power up components right in your hand. Instantly check components for continuity as well as identify positive, negative and open circuits without re-polarizing hook-up clips. Locate shorts without wasting fuses.
The 20ft. lead will allow you to test bumper-to-bumper without jumper leads. Audio tone indicates positive with a high pitched tone and negative with a low pitched tone. The audio feature can be disabled when testing relays. The Power Probe III has 2 cool white LEDs that flood the work area with bright light. The housing is sleek and feels great in your hand.
Features:
•Power Up Components
•Audio Tone
•Voltmeter
•12 - 24 Volt Range
•20ft. Jumper Lead Set
•Bad Ground Indicator
•Continuity Tester
•Short Circuit Indicator
•Relay and Component Tester
http://www.powerprobe.com/pp3.php
Last edited by F22; Nov 4, 2014 at 04:11 PM. Reason: Should've put III, not the II
You can use your 12 volt power supply and your meter in series with the 10 amp setting. But there is no automatic current limiting with this set up.
To get around this, what you can do is put a 1 amp sacrificial fuse in series as well.
So the hook up is +battery cable, 1 amp fuse, voltmeter set at amps, PS, then neg. battery cable.
This then gets you current limiting by burning out the 1 amp sacrificial fuse and you can see if you have any current draw with the voltmeter.
This is a lot of steps since you want to do this 1 car fuse at a time, but in the end you will be safe to hook up the car battery without frying anything.
With your power supply you should be able to run fan motors etc. by using a higher amp sacrificial fuse.
Don't fry your voltmeter amp setting since most of the better voltmeters only go to 10 amps, cheaper ones are less. Any higher current and you will fry this ammeter setting. the rest of the voltmeter will still work. There is a small wire inside the voltmeter where the current goes thru but it can only handle the max current and will burn out. The ammeter reading is really only a voltage reading across this wire.
Also check any loose wire ends particularily unmated plugs or light sockets that have exposed copper connection strips-tape these up.
I don't know of any other way of safely checking out harness that have been hanging out or rodents chewing on them. But I would be interested if someone has a better idea.
Steve L
73 coupe since new
Steve L
73 coupe since new
I was able to power up my 30 amp fan, easily with the Power Probe.
http://vid205.photobucket.com/albums...psa9fef975.mp4
For auto application, your gizmo looks better.
I never suggested to go buy a lab power supply.The are pricey. Some people have one hanging around for other projects. But again for the home restorer, I wouldn't buy a $130 test instrument either, just for a one time check of wiring harness. For shop use $130 is cheap considering it's versatility and it's continuous use.
If I didn't have a lab power supply, I would have used the sacrificial fuse approach mentioned above.
Steve L
coupe since new
Steve L
coupe since new
Here's a thought. I always factor in, what I call a "Time and Frustration" factor into a vehicle. Electrical has to be one of the most frustrating, difficult things to check on a vehicle and if I spend $80, $90 or even a $130 on a tool, like the Power Probe, that will save me hours of agony, then I'm all for it. I'd rather have the tool, than not.
Different strokes, for different folks. A multimeter will do it, but it's far easier and more intuitive, with the Power Probe!
Steve L
73 coupe since new
...might just have to make the investment of 130. If its that useful in sure I'll be using it often. I need to set up the radio also. Steve thanks for the wiring set up info.
key switch even worked as well as the a/c, blower and heater switches...now to begin putting it all back together...the 75 will ride once more.
