Hedman headers and burnt plug wires, help!
Old Aug 2, 2002 | 02:16 AM
gdh's Avatar
gdh
Default Hedman headers and burnt plug wires, help!
Just installed a new set of Hedman headers, I have Dart Iron Eagle heads with angled plugs. On the way home burnt a plug cap that was thouching the header, have 2 others on the drivers side that may go that route as well. The installer told me this would happen and suggested that I get headers plug wires. Any suggestions as to what to do would be appreciated. I was using an old set of cheap wires so no loss there. Also what wires are most of you running.
MSD6AL, Blaster2 Coil, Pertronix Ignitor2
Motor by our own Mountain Motor - exceeded expectations by a mile :cheers:
[Modified by gdh, 1:19 AM 8/2/2002]
Old Aug 2, 2002 | 07:56 AM
1Bad69's Avatar
1Bad69
Default Re: Hedman headers and burnt plug wires, help! (gdh)
greg..you can get the wires with different angles and lenghts on the spark plug boot...you just need to figure out what will clear... :cheers:
Old Aug 2, 2002 | 09:52 AM
Alwyn678's Avatar
Alwyn678
Default Re: Hedman headers and burnt plug wires, help! (1bad69)
I switched from Straight boots to Angle boots and that solved my problems
Old Aug 2, 2002 | 10:43 AM
gdh's Avatar
gdh
Default Re: Hedman headers and burnt plug wires, help! (Alwyn678)
Thanks all will do that today. :cheers:
Old Aug 2, 2002 | 11:39 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Greg, use NGK R5679-T spark plugs ( they are a little shorter ) and Taylor wires 074602 they have a 90 degree boot. With these plugs and wire you should have no clearance problems, but if you do heat the header up with a propane torch in the area where it is close and use a ratchet extension and a hammer to dent in that area a little bit then repaint the area with header paint.
Old Aug 2, 2002 | 03:24 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Default Re: Hedman headers and burnt plug wires, help! (MotorHead)
MotorHead,
Are the NGK's shorter than ACDelco's?
:seeya
Old Aug 2, 2002 | 04:56 PM
78pace's Avatar
78pace
just would like to know where did you get the headers going to be putting a pair on and if you dont mind how many $$
Old Aug 2, 2002 | 11:39 PM
gdh's Avatar
gdh
Default Re: Hedman headers and burnt plug wires, help! (78pace)
I just removed the ACDelco and the NGK/Accel are 1/4" shorter than the regular plugs. May have to dent one tube a little, much better than 3. Will put the new Taylor wires on when I install the MSD 6AL and Blaster2 coil. Also have to get 2 more bolts for the headers as the exhaust installer seemed to forget to do 2 of them as well as attach the rear driver side muffler hanger to the car, it just swings and bangs against the rear 1/4. He even managed to bend one of my tips, he did like his hammer. At least these things can be fixed.
The Hedman's were @ $250 incl. all taxes but that is in Canada so would be 1/2 that in the US.
To Hedman headers and burnt plug wires, help!
