Water in Gas Continued
Old Nov 8, 2014 | 08:46 PM
marines's Avatar
marines
Default Water in Gas Continued
Thaks to all the austute advice I received from you all, my water in the gas problem is resolved. I think I found the culprit as the drain was completely blocked. Blew it out with my air compressor hose, drained the tank with a 6.00 pump from Harbor Freight. Bought a minnow bubbler at WalMart (battery operated so no brushes that would create a spark) added, used a long tool with a compression release on one end and hooks on the other. Wrapped the device in electric tape to prevent any sparking. Used a rag at the end and "swabbed the deck", many, many times. Added Heet and SeaFoam when empty and swished it around. Changed fuel filter, blew out fuel lines, then added non ethonol high test gas (4 gallons), replaced plugs and hit the ignition. Purrs like a kitten. Thanks to you all for your sage advice.
