Need help with 75 4-speed convertible stuck in reverse
Old Nov 11, 2014 | 03:09 PM
LRB's Avatar
LRB
Default Need help with 75 4-speed convertible stuck in reverse
I know there is someone out there that can help me. I am not a car mechanic, but I do know my way around tools so I hope this is something I can fix. So far I have redone brakes and fuel pump.
My car is stuck in reverse. I was moving it and had to go back and forth to maneuver it into a position I needed it and it is stuck in reverse. No matter what gear I try to put it into is backs up. The reverse lights are on and it will not go into neutral. When I put it in 1,2 3 or 4th and let off the clutch, it dies.
Any help will be greatly appreciated.
Hoping to pick up my AIM tomorrow, but not sure it is will help.
Old Nov 11, 2014 | 06:41 PM
Phil Zell's Avatar
Phil Zell
Jack up the car, put shifter in neutral, get under car with box end wrench and put all gears in neutral position. Sounds like it is stuck in 2 gears.
Ask me how I know. Shifter is probably needing rebuilt or replaced.
Old Nov 11, 2014 | 06:59 PM
CanadaGrant's Avatar
CanadaGrant
As stated above, you are going to have to jack it up with the shifter in neutral and place the reverse shift lever in the neutral position. I don't agree that the shifter needs rebuilding. The linkage just needs adjusting. When you hit the neutral gate with the shifter it didn't pull the reverse shift lever all the way back and allowed it to pop back in the reverse position when you hit the gate. The rest of your gears still work but you end up stuck in two gears no matter what because you are still in reverse. Adjust the reverse rod length so it pulls the lever all the way out of reverse.
Old Nov 11, 2014 | 08:08 PM
rebel542's Avatar
rebel542
My 79 did the same thing and the threads on the adjustable linkage were worn out. You're able to shift into other gears but the reverse lever is stuck in reverse because your reverse lights remain lit whatever you do. You can replace the linkage and adjusters or just have the reverse linkage welded but one way or the other you're gonna have to remove it.
Old Nov 12, 2014 | 12:01 PM
LRB's Avatar
LRB
Thanks everyone for your assistance. I got under the car today and as Phil and CanadaGrant said, I was able to disengage the linkage and put it in neutral and everything worked. I will be updating the shifter linkage and shifter mechanism , but that will be a little later. Next is replacing front sway bar links and bushing. What is the best way to measure the sway bar to see which one you have? Based on what I have seen there are 3 options for 75, 7/8", 1 1/8" or 3/4". Do you measure the diameter? Again, thanks for all the help.
Old Nov 12, 2014 | 12:10 PM
MelWff's Avatar
MelWff
yes, you measure the diameter of the bar. I had the same experience with shifter caused by shift lever bolts loosening.
Old Nov 12, 2014 | 09:08 PM
20mercury's Avatar
20mercury
Default ditto the same problem
ditto the same problem on my 68 with a Muncie 4sp. Agree you need to adjust the shifter linkage. Might need to rebuild too depending on how much slop or wear you have.
Only thing I would add is if you check out the AIM and look underneath the shifter linkage towards the back you will see slots in each of the arms that need to line up in a row. You can make an alignment bar or tool to fit the slots as per the AIM or I just visually look to see if they are in a row and play with the adjustment until I get smooth shifts. I do not have a 75 AIM, but I think the AIM has a procedure outlined to adjust the linkage (or my 68 does anyway).
Hope this might help.
Old Nov 12, 2014 | 10:21 PM
LRB's Avatar
LRB
Thanks. Are you looking for that alignment from under the car on through the console?
Old Nov 13, 2014 | 12:12 AM
20mercury's Avatar
20mercury
Default shifter assembly alignment
You would be able to see the slots that you want to line up underneath the Corvette on the back or rear side of the shifter assembly just ahead of the parking brake pulley.
I doubt you could see the slots from above unless you could get a mirror down in there some kind of way.
Here is link to this forum that talks about what this looks like:
https://www.corvetteforum.com/forums...uge-lenth.html
This is in the C1/C2 section but the shifter on my 68 and 76 are the same setup, might be slots instead of grooves, still either way they are cut outs for alignment use.
I made an alignment tool, but found it easier to eyeball the lineup and get it close and then fine tune and play with the adjustment until you get a smooth shift.
Hope this helps.
To Need help with 75 4-speed convertible stuck in reverse
