L 82 Air Cleaner Temp Sensor
Old Nov 11, 2014 | 04:00 PM
Pi3_14's Avatar
Pi3_14
1st Gear
Default L 82 Air Cleaner Temp Sensor
In my hast to remove the hoses from the Temp Sensor in the bottom of the dual snooker air cleaner i did not note which end went to the carburetor for a vacuum source and which end connect went to the louvers in the in air cleaner inlet. When the engine gets warm the vacuum source is shut off and the actuates are deactivate and a spring pushes them open allowing cooler air to enter the air cleaner. What you have are two tubes out of the bottom to push the hoses on to. I assume there is a right way and a wrong way to connect the hoses.
Cannot not find any document to explain which end is up?
