Header Bolts.......@#$#@....how do you tighten them??
Old Aug 2, 2002 | 02:51 PM
LATNC3's Avatar
LATNC3
Default Header Bolts.......@#$#@....how do you tighten them??
i have this awfull exaust leak comicng from my headers. the reason for is because i can't get the 7/16 wrench to turn anymore....damn fire wall.....any suggestions on what type of tool to use.....???
Paso- If i can get the header bolts tight, i will order the flowtech's from you.
:mad :mad :mad :mad :mad
Rod :cool:
[Modified by LATNC3 (Rod R), 6:51 PM 8/2/2002]
Old Aug 2, 2002 | 02:56 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: Header Bolts.......@#$#@....how do you tighten them?? (LATNC3 (Rod R))
i found it easy to turn reaching up from under the car(the last one on pass side)
Old Aug 2, 2002 | 02:59 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Header Bolts.......@#$#@....how do you tighten them?? (Matt Gruber)
A great way to keep the headers tight is to cut the headerflange with a hacksaw between the pipes,that will allow them to move more freely and not leak...Just my.02 :cheers:
Old Aug 2, 2002 | 03:19 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Do you have room for socket head cap screws? The kind you use an allen wrench on? Bondhaus and others make "ball end drivers" which allow you to be up to 30 degrees off center with the allen wrench. You can put a small pipe or the proper size socket with an extension on the end of the wrench to tighten them.
:seeya
Old Aug 2, 2002 | 03:21 PM
Alwyn678's Avatar
Alwyn678
Old Aug 2, 2002 | 03:46 PM
Jester69Stingray's Avatar
Jester69Stingray
Craftsman makes ignition wrenches which are very small and have tow diffrent shaped ends. These make it easy for me to get to all of my header bolts.
Old Aug 2, 2002 | 05:13 PM
mrvette's Avatar
mrvette
I can't see any problem iwth dinging the hell out of the pipes and using a 1/4 drive socket set...and 7/16 head header bolts....work like a charm...
I"m lazy and use RTV to gease the threads on the bolts also....they stay tight that way too....
GENE
Old Aug 2, 2002 | 05:27 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Header Bolts.......@#$#@....how do you tighten them?? (mrvette)
I have the same problem, the two bolts closest to the firewall are a real ex-wife to get at, try using a crows foot with a universal on it. I have a real short box wrench that gets them almost tight.
Old Aug 2, 2002 | 08:17 PM
PatG's Avatar
PatG
Default Re: Header Bolts.......@#$#@....how do you tighten them?? (JRD77VET)
Allen head cap screws are the answer. You can fit the allen wrench almost anywhere and they work great on my headers.
I bought mine at a local bolt supply but here are some on summitt racing:
http://store.summitracing.com/partdetail.asp?part=11145
[Modified by PatG, 6:17 PM 8/2/2002]
Old Aug 2, 2002 | 10:09 PM
Disco_Mike's Avatar
Disco_Mike
I use a "stuggy" 7/16" craftsman wrench. works ok. i did have trouble with them working loose. bought new bolts and used high temp rtv gasket stuff.
things seem ok now. havent put many miles on them yet.
Old Aug 2, 2002 | 11:22 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I use Stage 8 locking header bolts and I've not had any problems with tightening them and especially with them loosening. I highly recommend them. They run about $30-35
Old Aug 3, 2002 | 06:40 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Header Bolts.......@#$#@....how do you tighten them?? (PatG)
To Header Bolts.......@#$#@....how do you tighten them??
