Engine Compartment help
Old Nov 12, 2014 | 03:43 PM
Jrstoke75vette's Avatar
Jrstoke75vette
6th Gear
Default Engine Compartment help
I recently purchased a 75 stingray with the 169HP motor in it. While debating on what to do about the engine (crate or slight 350 mod), I would like to clean up the engine compartment. I had a new radiator, fan shroud, Fan blades installed as well as a complete suspension rebuild. I would like to remove the factory AC and all components associated with it. Any suggestions? Just looking to make the car a funday driver.
Old Nov 12, 2014 | 06:55 PM
MajD's Avatar
MajD
Unless the A/C system is totally trashed and your car is a convertible, I wouldn't remove it. My C3 doesn't have A/C an I'm going to install it. The interior gets hot enough in these cars as it is, and it's doubly so without the a/c. Absolutely no fun to sit in traffic.
Old Nov 13, 2014 | 12:23 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you do remove the parts, be sure to hang on to them.
Old Nov 13, 2014 | 07:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Jrstoke75vette
...Just looking to make the car a funday driver...
Cruising with factory air is fun for a lot of us. Good advice from MajD.
To Engine Compartment help
