lower ball joints
Old Nov 13, 2014 | 11:43 AM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default lower ball joints
I just got all my front suspension rebuild parts. The LCA BJ is a bit of a strange looking duck. It has two "ears' sticking off of the ball "body" at 90 degrees to each other.
The existing does not have these...so, what are they for and how do you orient the BJ in the LCA so they are clocked correctly so as not to interfere with anything else?
Old Nov 13, 2014 | 12:10 PM
tracdogg2's Avatar
tracdogg2
All 63-82 Corvette lower ball joints have the two ears. If yours don't then we need to know what you are working on.
Mike
Old Nov 13, 2014 | 12:15 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
You haven't taken the old ones off yet have you?
It'll become apparent when you do
Old Nov 13, 2014 | 12:27 PM
phat87's Avatar
phat87
Default original
Sorry, it's a 1976 cpe. P/S.
The LCA BJ are the originals (riveted), no ears.
So what are the eras for? What do they do and how do you clock them?
Old Nov 13, 2014 | 12:39 PM
tracdogg2's Avatar
tracdogg2
The rivets go thru the ears. You have to drill out the rivets, remove the grease zerk, and the nut. There is no clocking, they only go in one way.
Old Nov 13, 2014 | 01:09 PM
phat87's Avatar
phat87
Default what!
Thanks for the cryptic responses. How would the "ears rivet to the LCA? the are well below the control arm when installed and lye in the wrong plane. They are vertical not horizontal.
Now I'm really confused. My AIM has no info on control arm details.
My Camaro AIM covers everything, by contrast.
Thanks, a pix would be very helpful or a referral to some pictorial information
Old Nov 13, 2014 | 01:23 PM
tracdogg2's Avatar
tracdogg2
How many rivets in the arm do you see? Two or three?
Old Nov 13, 2014 | 01:38 PM
TimAT's Avatar
TimAT
Lower Ball Joint. This one is a MOOG. The ears bolt into the lower control arm.
Old Nov 13, 2014 | 01:50 PM
phat87's Avatar
phat87
Default Ok
Well that's the craziest damn thing I ever heard of
Thanks for the help.
PS: from a strength of materials stand point it just seems counter intuitive to place a bolt in sheer. JM2cW
Old Nov 14, 2014 | 12:08 AM
TimAT's Avatar
TimAT
Here's a picture of one installed- sorry it's a little fuzzy. I was too.
Old Nov 14, 2014 | 06:37 AM
mikep3's Avatar
mikep3
PS: from a strength of materials stand point it just seems counter intuitive to place a bolt in sheer. JM2cW[/QUOTE]
The bolts are not in sheer, mostly anti rotation and flex reduction. The main loading is pushing the ball joint through the a-arm.
To lower ball joints
