Help with switch
Old Aug 2, 2002 | 07:37 PM
John D.'s Avatar
John D.
Default Help with switch
I do not know what this switch operates.
I am talking about a 1971 the switch in center of both overrides I call them pull down buttons that manually override lights and wiper door.
I thought it would turn wipers on and off so one could stop wipers on glass to change. But my switch does nothing. Any help please.
Old Aug 2, 2002 | 07:39 PM
lbell101's Avatar
lbell101
Default Re: Help with switch (John D.)
That IS what it's for. Is it plugged in?
Old Aug 2, 2002 | 07:43 PM
NHvette's Avatar
NHvette
Default Re: Help with switch (lbell101)
Never mind - answered by a 71 owner.
:seeya
[Modified by Daves_rusty_75, 6:44 PM 8/2/2002]
Old Aug 2, 2002 | 07:48 PM
Larry B.'s Avatar
Larry B.
It is supposed to stop the wipers on the windsheild so you can change blades. Turn the wipers on, then turn the block **** when the wipers are in the spot you want them..
Old Aug 2, 2002 | 07:57 PM
lbell101's Avatar
lbell101
Default Re: Help with switch (silvervetteman)
Agreed, it only turns them OFF not ON.
Larry
Old Aug 2, 2002 | 11:15 PM
John D.'s Avatar
John D.
Thanks for the answer. I will try the switch with the wipers on.
Old Aug 4, 2002 | 10:11 AM
John D.'s Avatar
John D.
You all were right. Did what you said and it works fine. Thanks to all.
To Help with switch
