Seatback Lock Problem
Old Dec 1, 2014 | 07:33 AM
Cavu2u's Avatar
Cavu2u
Default Seatback Lock Problem
I know what I did wrong. Now I need ideas on how to fix it.
I assembled the passenger seat seatback locking strap wrong.
The driver side was assembled (by me) correctly:
But the passenger side was assembled (by me) incorrectly:
The bottom anchor mount is reversed, not allowing the top latch to engage and do it's job.
I don't want to remove the upholstery to access the entire strap just to reverse the bottom anchor mount. Unless I have to.
Is it necessary to reverse the top part of the strap as well? I can't remember if it is directional, like the bottom is.
Any ideas?
Thanks,
Steve
Old Dec 1, 2014 | 10:43 AM
Ontario73's Avatar
Ontario73
Easy fix. Just unbolt the bracket from the seat bottom and pull the whole strip of steel out from the seat back guide. Flip it over and reinsert it into the guide. Made that mistake myself and there is no need to panic!
Old Dec 1, 2014 | 12:48 PM
Cavu2u's Avatar
Cavu2u
You guys are GREAT!
Thanks so much.
Steve
Proceeded as suggested. 30 minutes later, the seat now locks.
Thanks again!
Steve
To Seatback Lock Problem
