Fan clutch question
Old Aug 4, 2002 | 02:38 AM
1978shark's Avatar
1978shark
Default Fan clutch question
While replacing my water pump on my ’78 L-48 PC I decided to remove a few more parts to repaint and generally improve the looks under the hood. Tonight when starting to put it all back together I notice on page 317 of the Mid America Assembly Manual one note which read “the fan clutch yellow paint mark is to be matched with blue paint mark on O.D. & backside of water pump hub at asm.” I vaguely remember seeing that yellow mark as I was painting the flange on the fan clutch…..Does it really matter how the water pump, pulley, fan and fan clutch are bolted together?
Long time lurker, first time poster.
Old Aug 4, 2002 | 04:40 AM
Ben Taylor's Avatar
Ben Taylor
Default Re: Fan clutch question (1978shark)
As long as all four bolts/studs are the same and are torqued the same it doesn't matter which bolt goes in which hole as they are all symetrical.
Old Aug 4, 2002 | 11:45 PM
1978shark's Avatar
1978shark
Default Re: Fan clutch question (Ben Taylor)
Thanks for the reply Ben. For the life of me I could not figure out what difference it would make
To Fan clutch question
