I am replacing the original compressor in my 72 base engine because it has seized internally due to loss of refrigerant, and failure of the superheat switch and thermal fuse to protect it.
I have received conflicting clutch/pulley information from several vendors regarding the diameter of the pulley, specifically 5-inch versus 5-3/4 inches as my supposed original. The existing pulley - which I believe to be original - is the 5-3/4", but two of three reputable vendors have stated that this is incorrect for a small block. A look in the 1982 parts book was inconclusive.
Throughout my ownership of the car for 39 years, new belts have always been replaced "from the FLAPS book" and each new belt has always fit perfectly. The results were always mid-bracket adjustments and reasonable clearances from the exhaust manifold, rocker arm cover and inner fender. I believe the smaller 5-inch pulley would require a new, non-spec and shorter belt to obtain this same adjustment range.
I am prepared to buy the clutch removal tools to switch the pulley from the original compressor if necessary, while ordering a reman compressor without the solenoid, pulley and hub installed. I intend to retain the old core, which I believe to be original to the car.
Am I correct in assuming the original pulley for the small block is 5-3/4 inches in diameter, or are the vendors correct? I'd appreciate if some 71-73 owners would let me know what is on their cars, too. It is easy to tell - the 5 inch pulley is about flush with the clutch hub, where the 5-3/4 inch pulley "sticks out" from behind the hub.
I thought I was going to help, but mine seems to be even smaller!
I have a 72 LT-1 with a/c, and it is supposed to have a deep groove pully.
I just tried to measure mine and it looks even smaller than 5 inches. I do have a problem with the belt rubbing on the lower rad hose and have put a guard around it (tin can painted black ).
I do think it is a replacement compressor though. I've been thinking of going to an aftermarket direct replacement Cool Pro S6 compressor http://www.s6compressor.com/about.html
I've also reached the conclusion that most of the rebuilt compressors don't have provision for the superheat switch on the rear head. This is why I thought it best to have the original rebuilt, but it is big time $$$.
