Temperature Gauge Problem
Old Aug 4, 2002 | 09:50 AM
johnb74's Avatar
johnb74
Default Temperature Gauge Problem
Temperature gauge is dead and verified that sender is ok by grounding the feed wire with no needle response at all. I assume that I am getting no voltage at all since my tester light did not go on. Would you quess that I had a grounding or gauge problem here? Thanks guys or gals(I guess you need to be politically correct these days).
Old Aug 4, 2002 | 10:00 AM
mrvette's Avatar
mrvette
Default Re: Temperature Gauge Problem (johnb74)
if you ground the green sender wire, and get NO needle response, chek the bulkhead connector under the brakes....if not, you may have a bad gauge, or possibly wiring under dash....check plugs on back of gauge panels, one may be loose, for that matter the bolts on back of the gauges for electricals....
GENE
