Looking for some input
Long story short, it has been nothing but problems since we put it in. It's certainly faster, but it runs with a ragged feel to it. Noisy valve train, that we've adjusted a bunch of times, to no avail. The vacuum reading is pretty steady with only a mild flicker at about 12 hg. A quick acceleration, it goes to zero, then jumps to 23 or so, then quickly settles back, so that seems normal.
I've running an AEM air fuel ratio gauge with an O2 sensor and at idle, its moving all over the place and even going solid lean periodically. We tightened up everything, manifold, carb plate and even isolated the carb from all the external vacuum, with the same results.
I did a compression check and everything was at 150 or better, but that was a few months ago. We have gotten it to run smooth a few times, steady AF ratio, no valve train noise, but then it detoriates after a half day, the valve train gets louder and it picks up that ragged feel again. It accelerates hard, but has that sucky, rough feel, throughout the rpm range.
I'm not sure the engine builder reused my LT1 valve springs that I had before. In fact, except for the cam and balance specs, we didn't get a list at all, for what's in the motor. He used the cheapest cast pistons and I wonder how good the 'Custom' cam is as well.
Any input from the more experienced crowd here would be appreciated. We do a lot of work on a lot of cars at our shop, but building engines is something we haven't tried yet (though we can work with a short block). I know I got screwed, just looking to get it running right.
Funny enough, that fixed every friggin' problem that this car had. Noisy valvetrain, fixed, now it's quiet (go figure). Rough running, AF ratio all over the place, fixed. Now the AF ratio is steady at steady throttle settings and idle. Engine runs strong and smooth (again, go figure). Had a ton of valve clatter from the whole valvetrain and that's gone.
It now runs smooth and hard. Needs some more advance, but the real test, will be, whether it deteriorates and slowly returns to a noisy, rough running little bitch. But right now, just finished shining it up. Starts instantly, revs easy and Sassy is happy. Hope it stays that way...
We still need to put some advance into it.
I have motor #2, waiting to start ordering parts (once we know exactly what the block deck height is...). A lot of good advice here on a 383 thread and it's going to get done right next time.
I put Rhoads lifters in when I did my heads and cam, they are noisy but are good lifters, probably not your issue though.
