68 427 / 435 Dimple Rods
Old Dec 9, 2014 | 03:44 PM
68RPOL71's Avatar
68RPOL71
Default 68 427 / 435 Dimple Rods
In rebuilding my 68 L 71 Motor, I wanted to use 7/16 Dimple Rods but am finding they don't clear the block when assembled on the Crank. Were only 3/8 connecting rods used in 68 Blocks?
thanks,
Steve
Old Dec 9, 2014 | 04:29 PM
Corvettes by George's Avatar
0Corvettes by George
Former Vendor
correct
Old Dec 10, 2014 | 12:23 AM
Gale Banks 80''s Avatar
Gale Banks 80'
But many a Block has been clearanced to fit 7/16" Rod Bolts..........
Old Dec 10, 2014 | 09:42 AM
68RPOL71's Avatar
68RPOL71
any issues with making room for the larger bolts? Does is damage the block or cause any originality issues?
thanks,
Steve
Old Dec 10, 2014 | 11:31 AM
Indiancreek's Avatar
Indiancreek
The added strength is worth the effort to make the needed room. I wouldn't be concerned with someone inspecting the inside the engine to see if it's original or not. That wouldn't be any worse than Boring the block on a rebuild. In my opinion.
Old Dec 11, 2014 | 12:50 AM
Gale Banks 80'
thanks,
Steve
You need to grind a very little at the Oil Pan Gasket surface to get it to work. The guys who do the Stroker Motors grind a lot. Here is another way to look at it. If You start cross referencing Block part Numbers I'm sure You will find that the same Block You have came with both 3/8" and 7/16" Rod Bolt Rods. So how do You think the factory did it ? They ground it if it was needed.
Old Dec 11, 2014 | 09:14 AM
68RPOL71's Avatar
68RPOL71
Thanks everyone, I had the shop assemble using the 7/16" with very minimal modification. Thanks again for the insight.
Steve
To 68 427 / 435 Dimple Rods
