Wire Looms or Cable Ties
Old Aug 4, 2002 | 08:43 PM
Wrecked82's Avatar
Wrecked82
Default Wire Looms or Cable Ties
You can make some nice wire layouts using cable ties.
So, what do you use?
Old Aug 4, 2002 | 09:05 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Wire Looms or Cable Ties (Larry82)
I like being able to see the wires and what they run to. :smash:
Old Aug 4, 2002 | 10:49 PM
Red73's Avatar
Red73
Default Re: Wire Looms or Cable Ties (Wightnite)
Wire Looms.
Old Aug 4, 2002 | 11:03 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Wire looms here too!!
:cheers:
Olivier
Old Aug 4, 2002 | 11:06 PM
Alwyn678's Avatar
Alwyn678
Default Re: Wire Looms or Cable Ties (GrandSportC3)
:cheers:
Olivier
:cheers: :cheers: :cheers: :cheers:
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
:confused: :confused:
Wire looms keep the wires separated and look so much more professional. :yesnod: :yesnod: :yesnod:
Old Aug 5, 2002 | 04:40 AM
mnow's Avatar
mnow
Default Re: Wire Looms or Cable Ties (gb4622)
Old Aug 5, 2002 | 10:45 AM
Wrecked82's Avatar
Wrecked82
My problem is those dang air tubes keep me from using wire looms.
And, I actually was thinking about the push-on wire separators, vs. cable ties.
Wish I could use the real wire looms, but there is just so much junk under the hood of a smogged 82.
Old Aug 5, 2002 | 12:44 PM
Alwyn678's Avatar
Alwyn678
Old Aug 5, 2002 | 04:16 PM
Woodstoc's Avatar
Woodstoc
Default Re: Wire Looms or Cable Ties (Red73)
Very nice compartment Red73, I like! :yesnod:
Old Aug 5, 2002 | 04:26 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
If you have center bolt covers these are nice.
Mark B.
Old Aug 5, 2002 | 04:59 PM
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
Default Re: Wire Looms or Cable Ties (Sigforty)
Mark...who makes those looms?
Old Aug 5, 2002 | 05:39 PM
Sigforty's Avatar
Sigforty
Default Re: Wire Looms or Cable Ties (VetteBoy1979)
R&M makes them. I got mine through summit. They also make a loom for the regular bolt valve covers. You can also get them in some anodized colors.
Mark B.
Old Aug 5, 2002 | 06:17 PM
C3 Shark Tank's Avatar
C3 Shark Tank
These are the R&M looms for 4 bolt valve covers, they work great especially when you want to get your wires out of the way while you are working on the motor, just unplug them from the plugs and it all stays together.
Old Aug 5, 2002 | 06:37 PM
GrandSportC3
Default Re: Wire Looms or Cable Ties (C3 Shark Tank)
I had the same ones on my 69 Vert (sold). Those are very :cool:!!
Olivier
To Wire Looms or Cable Ties
