71 rear window defogger
I just rebuilt the blower motor on my 1971 ,rear window defogger - it was dated 12/69 and is original to the car. Original GM well nuts, no marks on the screws and a drop of yellow paint on one bolt. (top front)
My question is that there are 3 wires on the switch, the purple is high and the yellow w/ the fuse is the feed. I think I found somewhere (a month ago) that the other is a resister wire for low?
The high works fine, the low (?) only sparks lightly with no motor reaction. (if it is a resistor wire -then it's bad)
My Assembly Manuel shows only 2 wires as does my wiring diagram.
Is anyone sure if there was actually 3 wires on the switch.
My 72 does not have the option so I can't use as I have in the past as my go to example.
My next adventure(s) will be the melted speedo cable and clutch. Not sure if I will use the 90 degree for the tranny connection. If anyone has any thoughts it would be appreciated.
My question is that there are 3 wires on the switch, the purple is high .
PURPLE WIRE IS HIGH SPEED, TAN WIRE IS THE FEED AND THE YELLOW WITH THE FUSE IS THE LOW.
