LS1/4L60E drive shaft
Old Dec 21, 2014 | 10:34 PM
71 Vert LS1's Avatar
71 Vert LS1
Default LS1/4L60E drive shaft
Making some good progress on my LS swap.
Trying to figure out drive shaft and tranny slip yoke details.
Looks like the stock u-joints are 1330 and both bolt to the slip yoke and the rear axle yoke.
Can you advise which 4L60E slip yoke has bolts and straps? Part number ?
Regards,
Old Dec 22, 2014 | 09:57 AM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Regards,
A 4L60 is a 27 spline yoke, IIRC, but most 27 spline slip yokes with a bolt on u-joint for a vette are going to be 1310 style, not 1330.
Old Dec 22, 2014 | 10:00 AM
fleming23's Avatar
fleming23
You could use a combination u-joint and the following slip yoke. Depending on the power you plan to make, it might not be a big deal. Typically the bastard u-joints are frowned upon in any high HP situation though.
http://www.dennysdriveshaft.com/p9_c...style_27_.html
Old Dec 22, 2014 | 11:40 PM
71 Vert LS1
Thanks guys that's what I needed. Don't see that I have choice but use the 1330/1310 combo u-joint.
To LS1/4L60E drive shaft
