Jack It Up!
Old Aug 5, 2002 | 04:31 PM
l2vette's Avatar
l2vette
Default Jack It Up!
O.K. this is probably been asked 1000 times but, what is the best way to jack up the rear and set jack stands on a 72 shark???
:confused:
Old Aug 5, 2002 | 04:42 PM
trw's Avatar
trw
Default Re: Jack It Up! (l2vette)
Some people put the floor jack under the 3rd member (with a wood block). I usually do one side at a time, from the side of the car and place the stands just behind the doors.
Hope this helps.
Terry
Old Aug 5, 2002 | 04:44 PM
rreavis's Avatar
rreavis
Default Re: Jack It Up! (trw)
I 2nd Terrys method. One side at a time and carefully :yesnod:
Old Aug 5, 2002 | 04:51 PM
l2vette's Avatar
l2vette
That's why I ask, because the manual says to jack the rear (as well as the front) from the side at a specific location, I just wonder where you place the jack so that when jack it up, you can set the jack stand at the proper position on the frame.
Old Aug 5, 2002 | 06:07 PM
jerryp58's Avatar
jerryp58
If I understand what you're asking, I usually put the jack on the inner edge (towards the center of the car) of the cross hatched section and the jack stand on the outer edge http://users.erols.com/jerryp58/corvette/jackpts.jpg . It's a tight fit with the hydrualic floor jack, but I think it works OK.
[Modified by jerryp58, 5:08 PM 8/5/2002]
Old Aug 5, 2002 | 06:47 PM
l2vette's Avatar
l2vette
Thanks for the info!!!
To Jack It Up!
