Lubricating sway bars?
Old Aug 5, 2002 | 11:51 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Lubricating sway bars?
My rear bar is squeeking around the poly bushing that holds it to the frame, can it be lubed?
With what?
Old Aug 5, 2002 | 11:55 PM
71stingraybigblock's Avatar
71stingraybigblock
Default Re: Lubricating sway bars? (427V8)
When I did the install of VB perf plus susp. they included a little tube of lube for the sway bars. What type I am not sure.
Old Aug 6, 2002 | 12:07 AM
427V8's Avatar
427V8
Default Re: Lubricating sway bars? (71stingraybigblock)
OK I'll answer my own question since I waited a whole 5 minutes :rolleyes:
From the Addco web site. ( they actually make VBP's sway bars )
http://www.addco.net/install.shtml
Mid-section bushing bracket should not be allowed to squeeze the bar. Over tightened bushings will result in noisy bar operation and accelerated bushing wear. If curved or uneven frame surface causes the bracket to squeeze the "D" bushing onto the bar, the bracket should be shimmed up with a washer. Synthetic brake caliper or a marine grade grease can be used on tight fitting rubber bushings. Urethane mid-section bushings must be lubed.
[Modified by 427V8, 10:09 PM 8/5/2002]
Old Aug 6, 2002 | 12:10 AM
71stingraybigblock
Not very much action tonight.
Old Aug 6, 2002 | 02:57 AM
Chris O''s Avatar
Chris O'
...me neither! :p:
To Lubricating sway bars?
