Lifter failure
Old Dec 29, 2014 | 07:39 PM
VetteNURSE's Avatar
VetteNURSE
Default Lifter failure
I have had 2 seperate issues with comp cam hydraulic flat tappet lifters. The first one was 700 miles after rebuild and the next was recently, 3k miles after rebuild. Both cases the retainer let go, the lifter came apart and it ate the rocker end of the push rod. It was one the first time and 2 lifters this time. Anybody ever have this happen? I would like to hear opinions as to why it happened, maybe over reved? I have a 6200 rpm rev limiter set and it did not hit it. The most important question is what lifter to replace it with so it doesnt happen agsain.
Thanks in advance for info,
Mike
Old Dec 29, 2014 | 08:15 PM
Ironcross's Avatar
Ironcross
Mike
Incorrect lash on a few lifters, ..or not enough clearance between retainer and guide, coil bind with lift and a seal is also involved if your looking for causes.....all should be addressed to find a cause
Old Dec 29, 2014 | 08:23 PM
VetteNURSE's Avatar
VetteNURSE
Can you give more info on clearance between retainer and guide? Not sure what you mean. This is a 355 with a 490 lift cam all matched comp cam components.
Old Dec 30, 2014 | 09:40 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Fairly common with the "hairpin" wire retainers. It can happen from over revving and or when you try to "zero" lash them. The clips can't hold everything in place when the plunger comes up against them in either case.
Look for lifters with the true c-clip style retainers in them.
JIM
Old Dec 30, 2014 | 11:48 AM
REELAV8R's Avatar
REELAV8R
Lack of spring control can allow the lifters to pump up as well then same results with plunger coming up to the retainer.
To Lifter failure
