Alternator Wires - some not needed?
Old Dec 30, 2014 | 03:47 PM
retrodude's Avatar
retrodude
Default Alternator Wires - some not needed?
I just ordered a chrome Powermaster alternator since I'm changing to a serpentine belt system and moving the alternator to the passenger side. Tech support says that I only need the one power wire going to the alternator. Currently I have the one power wire and the two wires that are in the side, with a plug. He said the two wires on the plug just go to the external regulator and I can remove them.
Does this sound right to you all?
Thanks, Allen
Old Dec 30, 2014 | 05:48 PM
Peterbuilt's Avatar
Peterbuilt
Yes, sounds correct and here's how it works.
http://bob_skelly.home.comcast.net/~...ternator1.html
Old Dec 30, 2014 | 06:47 PM
PeteZO6's Avatar
PeteZO6
I respectfully disagree. Carefully read the link in Peterbuilt's post above. The sense wire is essential to ensure the correct charging rate for the entire car electrical system. When you use a one-wire alternator, the regulator only senses the alternator output, it "ignores" the car's requirement.
GM wouldn't have wasted money on the sense wire it weren't necessary for proper operation of the electrical system with all the various loads.
The only good reason to use a one-wire alternator is its simple to wire.
Pete
Old Dec 30, 2014 | 09:12 PM
toddalin's Avatar
toddalin
Yes, you can just unplug them and tuck them back, or cut them off for that matter if you never intend to go back. You can also remove the regulator and its plug as they are no longer used.
I've had a 1-wire on my '64 for many years with just a red wire going to the horn relay and I grounded the black wire to the case, though it isn't necessary. Works fine.
Old Dec 31, 2014 | 11:29 AM
retrodude's Avatar
retrodude
Thanks everyone, I appreciate the info. Peterbuilt, that was a great link too!!
Old Dec 31, 2014 | 12:05 PM
my 76 ray's Avatar
my 76 ray
Thanks Peterbuilt. Now all I have to remember is that I always want a 3 wire alternator ... and I know why.
To Alternator Wires - some not needed?
