MSD 5095 Starter
Old Dec 30, 2014 | 07:21 PM
greenvette73's Avatar
greenvette73
4th Gear
Default MSD 5095 Starter
I am in the process of installing an MSD 5095 starter on my 1973 corvette. I have removed the stock GM starter and now installing the MSD. I have an MSD 6AL ignition, MSD blaster coli, and an MSD distributor.
How do I wire my new MSD starter? I have too many wires and not enough connections on the new starter. If anyone has any pictures that would be very helpful.
Old Dec 30, 2014 | 07:40 PM
Peterbuilt's Avatar
Peterbuilt
Just use the purple wire, you won't need the yellow ( no "R" terminal) with that starter.
The black is the ground for the wiper and heater motor, it goes on a starter or bell housing bolt.
Old Dec 31, 2014 | 05:45 PM
greenvette73
4th Gear
Thank you very much for the info. and diagram. Everything is installed and working perfectly.
To MSD 5095 Starter
