Which Front Coil Spring?
I'm in the process of rebuilding the front end and need advice on the front coil springs. I'm trying to decide between the 460lb and 550lb spring.
1. Will both springs work well with the 9 leaf stock rear spring?
2. Has anyone had issues with the 460lb spring actually raising the front end due to the old springs sagging from age.
3. If the 550lb would work, is there really that much of a difference in ride quality due to the 460lb and 550lb spring rate being so close together.
Basically I'm leaning towards the 460lb spring unless it would raise my ride height and force me to cut the springs which at that point, I might as well go with the 550lb springs if they would work.
Thanks, Eric
Thanks, Eric
After taking around 180lbs off the front of my car I had to cut the stock front springs one coil to stay level. But they're much too soft so my plan is to go 550lb 2" lowered coils when I get 17" rims/tires and Bilstein HD not Sport shocks. I might consider the 460lb springs if I were using a harder 18" tire but I'd likely still have to cut a coil due to the weight loss. I do have a 7 leaf rear spring and Koni adjustables in back though which would make a good match with the heavier coils up front. Sorry to ramble on but I'm at work and rushing a bit.
3. You're only talking about roughly 45 in/# difference in effective wheel rate - the value that really matters. And, given that you must support the nose anyway, I wouldn't put too much emphasis on the percentage difference between the two choices you're considering.
Of course, if comfort trumps handling, the discussion is moot.
Ride is fairly stiff, but, I don't care as it is a track machine.
Eric
