stroker kit vs. crate
Old Aug 6, 2002 | 01:02 PM
69chromebumper's Avatar
69chromebumper
Cruising
Default stroker kit vs. crate
I was looking to get a zz4 crate but I was reading in posts from the past that a stroker kit with good heads will produce about 350hp to 400hp. Is this true and or worth it?
thanks :flag
Old Aug 6, 2002 | 01:15 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: stroker kit vs. crate (69chromebumper)
ZZ4 is about 350 HP my personal preference would be a 383 buildup only if you can find a good high performance engine builder. :D
Old Aug 6, 2002 | 01:28 PM
69chromebumper
Cruising
Default Re: stroker kit vs. crate (MotorHead)
is it hard to build up an engine?
Old Aug 6, 2002 | 04:27 PM
Fevre's Avatar
Fevre
Also look at the HT 383. It has a forged crank and roller cam, and after warranty would make a very solid foundation for a 500+ hp engine. If I had to do it all over again I would have bought one to start with.
Old Aug 6, 2002 | 04:38 PM
Sleestak's Avatar
Sleestak
Default Re: stroker kit vs. crate (Fevre)
Go for the best of both worlds. I was going to go this route but I think I'm just going to do a ZZ4 w/Hotcam setup and save a few $$$.
Old Aug 6, 2002 | 06:30 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: stroker kit vs. crate (Vfastboy 73)
ive always built all of my motors since i was 15 but lately seeing these zz4 motors run at the track they really impress me...ive had 383 350 327 406 283 377 but for the money and a warrantee the zz4 would be a good way to go.It really all depends on what your looking for.
Old Aug 6, 2002 | 07:50 PM
MotorHead's Avatar
MotorHead
It's fairly easy to build a motor, keeping them from blowing up once you put them back in the car is the hard part :D
Old Aug 6, 2002 | 08:51 PM
72rdstr's Avatar
72rdstr
:yesnod: Fevre is spot on. HP Chevy magazine (I think?) has been doing a continuing article of a HT383 build up.
With TFS 215 heads, a cam, and performer RPM intake, they're getting 500 ft/lbs of torque.
This is truly rocking for a streetable SBC and is the path I've decided on! :blueangel:
Old Aug 6, 2002 | 08:57 PM
Corey_68's Avatar
Corey_68
Building it isn't hard at all, the key is clearance. With out the proper clearance, you'll motor will NOT last very long. :nonod:
Old Aug 6, 2002 | 10:04 PM
Dr_stingray's Avatar
Dr_stingray
Default Re: stroker kit vs. crate (Corey 68)
why go with a 383 when you can have bigger! Like me, 496 stroker :eek:
To stroker kit vs. crate
