700R4 hesitating in DRIVE!
Old Jan 5, 2015 | 11:47 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Default 700R4 hesitating in DRIVE!
ROOKIE PROBLEM........
If anyone has a clue: My 700R4 that is now in my '34 street truck will soon be swapped with the TH400 that is in the Vette project inorder to drop cruising rpm and increase mpg. I will put a rebuild kit in it before the swap.
I've spent hours doing searches, but no site has a definite answer.
When hot or cold the transmission hesitates for about 5 seconds when it is shifted into DRIVE.....it doesn't hesitate at any other time.
I have installed a dash-pressure gauge, serviced the unit/tried different fluids and additives/replaced servo-seals-etc with no good results.
According to the test-charts, the operating pressures are perfect in all gears and at all speeds/it shifts itself perfectly....it has an external fluid cooler....I have always serviced it every 20,000 miles.
I think it's a valve body problem, but would rather change a $30 piston or spring, than a $250 valve body (and STILL not solve the problem).
Problem is...being a rookie....I can't decide which piston, spring, or servo in the transmission needs to be replaced.
Has anyone had/heard of a similar problem?
Old Jan 5, 2015 | 07:14 PM
TimAT's Avatar
TimAT
When you put it in gear is the pressure rise instant or does it take that few seconds to come up?
My first thought is either the pump regulator filter has caught some trash, the pump is lazy or maybe even the lo-reverse clutches have too much clearance.
Old Jan 5, 2015 | 10:16 PM
doorgunner's Avatar
doorgunner
I'll post the results tomorrow....with the cold and hot transmission results....and thanks for the input.
Old Jan 7, 2015 | 01:12 PM
Kacyc3's Avatar
Kacyc3
Also try pulling it down to first when you initially would go to drive.
Old Jan 8, 2015 | 01:00 AM
doorgunner's Avatar
doorgunner
Sorry.........I got side-tracked....I post the results tomorrow
(and subscribe to my own thread so I can find it!)
Old Jan 8, 2015 | 01:07 PM
David Mc's Avatar
David Mc
I don't believe there is a pressure difference between park/neutral and drive. The pressure does increase when selecting reverse.
Pet peeve- I hate the term "hesitation" when describing transmission concerns. "hesitation" is an engine performance/drivability complaint.
If I had to guess, I would think the seals for the forward clutch are hardening and leaking. If you select manual 1st is it the same?
Old Jan 8, 2015 | 05:50 PM
doorgunner's Avatar
doorgunner
I drove the truck today (what would be a good term to use instead of "hesitates"?):
36*F ambient air (approx. the same results on a 95*F day/all psi readings 10% less)
80 psi cold in PARK
150 psi cold in REVERSE
80 psi cold in DRIVE with brake on
105 psi immediate rise while driving at any speed
70 psi in PARK with transmission warm ( at operating temperature)
145 psi immediate rise in REVERSE warm
70 psi in DRIVE warm with brake on
95 psi while driving at any speed
So....there is a 10 psi drop in pressure at operating temperature.
(I forgot to try 1st gear manually)
Is that enough info for you to make a conclusion....
or do you want me to do the 1st-gear manually tomorrow?
Thanks, doorgunner
Old Jan 9, 2015 | 12:17 PM
David Mc's Avatar
David Mc
Yes, it's "delayed engagement"
Try the manual low thing. If it immediately goes into gear then you can conclude the low roller is slipping. It's mechanical and not hydraulic.
Old Jan 9, 2015 | 03:32 PM
doorgunner's Avatar
doorgunner
Delayed engagement........Got it!
This afternoon I will drive the truck and check for delayed engagement in low gear. I'll post the results tonight.
Old Jan 9, 2015 | 08:45 PM
doorgunner's Avatar
doorgunner
Cold or operating temperature......when I manually shift it into low gear it still delays engagement.
So I can rule out mechanical problems............ a quality rebuild kit will give me a good solid transmission again.
Old Jan 11, 2015 | 08:47 AM
doorgunner's Avatar
doorgunner
Somehow.........I didn't adjust the TV cable correctly when I added the 700R4 carb linkage adapter to the Holley on my '34 SBC truck.......
it won't solve the delayed engagement problem, but it may stop the tires from "barking" when going into 2nd gear under moderate acceleration...a little rough on the neck with no headrests......LOL!
Old Jan 14, 2015 | 10:26 PM
doorgunner's Avatar
doorgunner
The TV cable adjustment worked....no more neck snap with 2nd gear shift.....I must not have fully engaged the adjust-button previously and the cable tightened up some!
Now....to collect rebuild parts.
Old Jan 15, 2015 | 03:17 PM
TimAT's Avatar
TimAT
There should be a shop that sells nothing but trans related parts- there are 2 or 3 in Kansas City that I've used. Prices vary a little between them, I usually go to the same one because the guys there seem to have a better handle on what's needed and I don't forget something. Rubber, paper and faced clutches runs about $125 IIRC. Add a front pump bushing, the 10 vane pump kit, and a filter. The ones I usually see are smoked big time so I usually get a convertor too. Out the door for between 200 and 250.
I forgot- I always get a shift kit- I prefer Superior, but had good luck with the Trans-Go kits too.
Old Jan 15, 2015 | 05:12 PM
doorgunner's Avatar
doorgunner
Even though the transmission is doing a great job (except for the delayed engagement in DRIVE) I will get a new lock-up torque converter/clutches/seal & gasket kit........because.......after a rebuild at 125,000 miles............
the transmission now has................223,000 miles on it.
Who said 700R4(s) don't hold up well?................LOL!
Old Jan 15, 2015 | 05:53 PM
TimAT's Avatar
TimAT
Must be an 89 or later 700R-4. The rear planetary gears were not real great before that. I worked at a Chevy dealer in 85-86. They had 9 parts delivery trucks. In the span of one week 6 of them blew the rear planetary gears apart. And that was back when warranty paid 14hours to R&R and rebuild.
Easy to tell the new style- the inner gearset has an oil slinger pressed on and the outer gear has chamfered edges and a line on one of the teeth the parking lock goes into.
Old Jan 16, 2015 | 11:09 AM
doorgunner's Avatar
doorgunner
I did a search on the case-numbers of my A/T......it's an '89 with 3rd and 4th lock-up!
Old Jan 16, 2015 | 03:33 PM
TimAT's Avatar
TimAT
That's good news. It should have the updated rear planetary set and a 10 vane pump. Just replace the rings in the pump with the hardened rings and drive on, provided the rest of the pump looks good.
To 700R4 hesitating in DRIVE!
Old Jan 16, 2015 | 10:56 PM
doorgunner's Avatar
doorgunner
About 5 years ago I replaced the front seal....I took the pump apart to check the vanes....they looked perfect and the pump walls were slick/no grooves....it has very good pressure and is 10 vane.
Thanks for the replacement info!
Old Mar 5, 2015 | 12:27 AM
doorgunner's Avatar
doorgunner
I got side-tracked with the purchase of a complete soft top assembly!
The trans. Rebuild is still on the list though.
Maybe in another month...I'll post the pics in my build thread.
Old Mar 5, 2015 | 07:48 PM
mrvette's Avatar
mrvette
TimAT knows his **** and is a friend of mine that is seldom scene since his Jax Flip daze seem over with.....
he has helped my greatly over the years with auto trans issues, so keep your ear to the ground.....
