1.6 roller rockers ?
Old Jan 7, 2015 | 04:10 PM
J.D.78's Avatar
J.D.78
Default 1.6 roller rockers ?
just about got my engine buttoned up from head and cam change. have 1.5 roller rockers that were on the engine . my buddy has a new set of 1.6 roller rockers I can have for $50. I have plenty of valve to piston clearance . dished pistons , 56 cc trick flow heads , and this cam. http://www.summitracing.com/parts/hrs-cl110041-12
would 1.6 rockers be a good idea ??
Old Jan 7, 2015 | 04:19 PM
REELAV8R's Avatar
REELAV8R
Using the 1.6 would put your lift on the exhaust up to .520 from .488. If you got the piston clearance and are far enough from coil bind (.060) at that height and have no valve guide interference problems, then I would say yes, its worth a try.
It will make the cam behave like it a has little more duration. You may also need different length pushrods. Looks like pretty decent duration already on that cam.
Old Jan 7, 2015 | 07:52 PM
J.D.78's Avatar
J.D.78
thanks ree. if I have to get new length rods then I wont do it now. might redo bottom end of engine with better pistons next winter. I will look into it then.
Old Jan 7, 2015 | 08:12 PM
Cool95vette's Avatar
Cool95vette
As cheap as pushrods are why not? Even if you don't use them now I wouldn't pass on the opportunity to buy them. $50 is a good deal.
Old Jan 7, 2015 | 08:26 PM
96 lt-4's Avatar
96 lt-4
I would run them on the intake side only.No benefit from running them on the exhaust.
Old Jan 7, 2015 | 09:15 PM
Solid LT1's Avatar
Solid LT1
if your running most OEM Chevy heads the 1.6 ratio rocker wont work without opening up the pushrod hole....Google " Louis Tool " to get the details before you cause yourself problems.
Old Jan 7, 2015 | 10:07 PM
7t9l82's Avatar
7t9l82
the factory heads need some clearance work. the exhaust port on factory heads doesn't flow fantastically well and a 1.6 rocker will help on the exhaust. if the other items mentioned check out i would say go for it. if i remember correctly it affects lift about 30 thou, and duration marginally.
Old Jan 8, 2015 | 12:38 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
What brand of rockers are the 1.5 and 1.6's? Some of the cheap stuff I'd never use.
JIM
Old Jan 8, 2015 | 10:43 AM
Little Mouse's Avatar
Little Mouse
Your trick flow heads you can just about bet have push rod clearance built in to them to use a 1.6 rocker. The aftermarket has known for a long time now that 1.6 rocker use is a very common thing done to the SBC. It won't be a round hole like the factory used you can see the difference just by looking at it. Extra lift you need it there is no doubt about it in your case, your below .500 lift with your cam. Even the poor air flowing factory heads liked a little over .500 lift. The 1.6 rockers extra added lift will help you even more so with the better breathing aftermarket heads you have. Push rods plenty good enough for what your doing do not cost much. You don't need the latest greatest .080 thick expensive push rod's for a flat tappet hydraulic cam. Very good point on what brand of rockers they are.
Old Jan 8, 2015 | 06:14 PM
J.D.78's Avatar
J.D.78
guy is in the hospital with pneumonia right now so not sure what brand. I think the 1.5's I have might be cheapies. only I small circle with 1.5 in it. no other markings anywhere, so if I decide to use them how do I know what pushrod length to use? I could always swap the rockers and rods later when the weather warms up. getting antsy to get it running. new side headers coming tomorrow .
Old Jan 8, 2015 | 07:17 PM
Little Mouse
Sure you can do it later but you can benefit from a 1.6 its not a waste of your time to do it whenever you decide to.
buy a push rod length checker. You can magic marker tip of valve, get the mark the roller leaves centered and narrow on the tip of the valve will work. Then just look up the length push rods you need.
Old Jan 8, 2015 | 10:26 PM
REELAV8R's Avatar
REELAV8R
Centered and narrow might not be possible. Go as narrow as possible, whether centered or not.
Old Jan 9, 2015 | 11:44 AM
bashcraft's Avatar
bashcraft
I would use the 1.5's to break in the cam and then change to the 1.6's later.
To 1.6 roller rockers ?
