Do I need a new alternator???
Old Jan 9, 2015 | 01:01 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Do I need a new alternator???
Two (2) questions....One (1)...if my multi-meter reads 14.7 volts coming out of the alternator (red lead to the back of the alternator while the engine is running and the black lead to a good ground) and the battery reads 14.6 volts... do I need a new alternator?
And (2) will a 140 amp or 100 amp alternator hurt the battery or the wiring system?
The reason I'm asking is because I just got a brand new 770 CCA battery from Advance Auto. I connected a Battery Tender up to it and got the green light (after about 30 minutes of charging). After starting the car, and driving it for about 30-45 minutes and rehooking the Battery Tender when I got back, it takes about 3-4 hours before the battery is fully charged. So I'm wondering if the alternator is heading south....
Do I need to get a new one???
Old Jan 9, 2015 | 02:00 AM
dugsgms74's Avatar
dugsgms74
I think all is good. 14.6v is plenty and length of time it takes for the battery tender to go solid green isnt really a good way to gauge charging system condition. If anything, get the battery load tested and if its good dont give it another thought.
No, a high amp alternator wont hurt anything except your pocketbook. But unless you have alot of add on electrical equipment(electric fans, big stereo, etc.) you probably dont need one.
Old Jan 9, 2015 | 02:13 AM
terrys6t8roadster's Avatar
terrys6t8roadster
13.6 to 14.2 VDC is factory spec on GM charging rates with the Delcotron alternator. Unless you have added any electrical accessories you don't need to up alternator output. Jegs has a kit to upgrade the Delcotron alt to 100 amp output for $40. Then you should increase the output wire size from the 12awg wire to at least a 8awg. T
Old Jan 9, 2015 | 07:13 AM
mike48750's Avatar
mike48750
You can also find someone with a load tester like a VAT40 or MT522 that can put a load on your electrical system and read the output amps. If you have a failed diode in the alternator it can still show good voltage with a reduction in amps available. As has been noted the time to obtain a green light with a tender is not a sign of condition of either your battery or charging system. Mike
Old Jan 9, 2015 | 09:29 AM
hugie82's Avatar
hugie82
If you're running a glass mat battery 14.7 is perfect.
Old Jan 9, 2015 | 10:04 AM
Mike Ward's Avatar
Mike Ward
It's normal for battery tenders to take 3-4 hours to make up their mind.
Old Jan 9, 2015 | 02:02 PM
Richard454's Avatar
Richard454
Rather than guessing at a green light....
You might have 14.7 V DC BUT how much AC?
Here's how to tell if your diodes are in good shape-
With engine running about 2500RPM and headlights on- measure the AC voltage at the alt- output on one lead and the other lead on the alt's case.
Should be less than .5 volts AC.
A bad diode will drop 33% of Alt's output.
Richard
Old Feb 2, 2024 | 01:10 PM
gsflyer2011's Avatar
gsflyer2011
1-NOPE!, those are normal numbers,
2-No, 140m AMP alt is designed for our cars and it will do no harm to it. Because it is triple regulated, it only puts out what the electrical system is demanding, nothing more. Our OEM alts after a while (they get old and tired) and not provide enough amps at stop lights but your numbers are good. So too many ted lights, you are draining your battery instead of charging it.
3-Yes that is also normal for your charger to take 2-3 hours because if it is CTEK, it is running some tests first to see where the battery is.Because it is good, you get green in 3 hours. If your battery was really low, it would even take overnight of charging to get to green.
Old Feb 2, 2024 | 06:23 PM
HeadsU.P.'s Avatar
HeadsU.P.
Note the dates, gsflyer2011
Old Feb 2, 2024 | 08:58 PM
gsflyer2011
Wow, thank you. I wonder what is going on with CF? It just mailed me the previous response, I assumed it was recent. Maybe I am loosing it.
Old Feb 3, 2024 | 08:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Also...if you are on a thread and go to far past the bottom sometimes you end up on a related thread which can either be the wrong topic or from decades ago...it happens to everyone eventually
To Do I need a new alternator???
