C3 Convertibles - Deck lid protector question...
We call it armaflex. Black about 1 1/2" diameter to go over copper piping. Sized for copper pipe 5/8 I.D. or 7/8 Id. Comes in I think 5 foot long may be six feet can't remember.
This is very flexible and will form to contour of top.
May not look the best but should protect deck.
Now I will have to decide what I'm going to do.... There will be a short term solution for this weekend. The long term solution will probably be what Juliet suggested. Getting the vinyl and cutting it to the right dimensions... I might even cover the complete deck with transparent vinyl...
:cheers:
Olivier
any pipe wrap in that position is same as the weatherstrip...it gets dirt and road grit under it, and it vibrated/wears itself into the paint.....
ever notice the c4 with the vinylised wear strip/part of hatch that the top rest against.??? so it don't do what your cars do...wear the pattern into the paint....I can assure you I have tried most every trick in the book on that back when I had my hardtop, and the ONLY thing what worked was that aluminum tape from a/c work....not duct tape, but METAL tape....looks ugly withhardtop off, but that' the breaks....
NOW for the soft top...I just adjust the latch bolts down a bit, allowin the top rear bow to ride higher, keeping majority of pressure off the deck....
limits the damage somewhat...still leaves a mark though...
GENE :D
GENE :D
:cheers:
Olivier
maybe I"m just unlucky there, but well that tape is at Home Despot, and the cut vinyl cling is on order somewhere...
GENE
:cheers:
Olivier
P.S. For the long term- I'm still looking for some transparent vinly...
